Mazda Tribute Alarm and Security System Questions
guttermangutterman Member Posts: 1
ACCORDING TO THE MANUAL THE STANDARD FITTED ALARM CAN ONLY BE SET OFF BY ILLEGAL ENTRY CAN ANYONE TELL ME HOW I CAN SET THE ALARM OFF TO CHECK IT IS WORKING
ALSO IS IT POSSIBLE TO LOCK THE VEHICLE WITHOUT SETTING THE ALARM AS WE TRAVEL ON FERRIES AND IM NOT SURE WHETHER THE ALARM IS ACTIVATED BY MOTION AS WELL AS ENTRY
  • edwardc3000edwardc3000 Member Posts: 30
    I recently purchased a 2005 Mazda Tribute. I live in the Bronx,NY so an alarm is a minimum necessity.
    Here's the problem, and what's I've done so far:
    I press the LOCK button on the remote and the doors audibly lock.
    I press the LOCK button a SECOND time and I hear a CHIRP indicating that the alarm is set.
    However, if I leave a window open and open the door from outside with the alarm set, the alarm does not sound.
    I've checked to make sure that it isnt just ONE door switch by trying this with all the door and the hatch, and the interior light does come on.
    My GUESS is that there is a valet switch somewhere, to keep the alarm from blaring as it was going through a car wash. But I havent found it and have read the manual from beginning to end.
    Also, I pressed the panic alarm so that I'm sure the alarm itself is working.
    Please someone help me out...
    Many thanks
    ED
  • miradzymiradzy Member Posts: 2
    My keyless remote omega 352 -07 does not lock and unlock the doors,when u press the buttons the led flickers.can anyone help me to reprogram the remote and where can i locate the valet switch on the vehicle and how does it look like.
    can anyone send me a pdf of the owners manual of the tribute 2005
    Where To Find Your Car Owner's Manual Online may help. :)
    SUVs and Smart Shopper
  • pepetruenopepetrueno Member Posts: 1
    did you get help with this question?
    I have the same issue and I will like too see if something is wrong with my alarm system....
