Acura TL Wind Noise
I am experiencing a wind noise in the driver side window of my 07 TL. This usually happens when there is a crosswind coming from the passenger side. Had the vehicle in for warranty work and was told the problem is inherit with most 07 TL's. I am curious if anyone else has experienced this and if so what was your solution. I find it hard to believe that there isn't a remedy for this.
Here's my temporary solution:
I drove on a 35mph and 60mph highway. Make sure all windows all closed even moonroof, no music or any sound inside the car. (Driver side window) roll up the window all the way up, then pushed the down button a little bit (like you tap the button until you see the window move down just a little bit)
I did this and the wind noise disappear, but if you roll up the window all the way up the wind noise is back again.
When you brought it to the dealer, did they fix it? And that's all they told you that it was inherited?
No the dealer did not fix the problem. They said they test drove other 07 TL's on their lot and they had the same problem, which is why they said it is "inherit" with these models. I can't believe other owners are not having a problem. You would think there would be a service bulletin out there on this problem.
What state are you at? Because I'm going to try to make an appoinment for it. if they can't fix it I'm going to have them replace the window or window seal.
Let me know if the wind noise was gone when you tried the temp solotion.
http://tl.acurazine.com/forums/showthread.php?t=155308&highlight=wind+noise
I've read others use a silicone based lubricant on the seals.
Hope this helps.
I am at the point now where I just want it fixed and nobody at Acura (dealer or manufacturer) is responding here.
