Subaru Legacy/Outback Transmission Problems
in Subaru
Having transmission problems, post here?
I have a very annoying problem with my 2001 H6 Outback. A few weeks ago the battery light and the exclamation point light came up on my dashboard and a few minutes later the car died - no power.
I've waited an hour or so, started the car and drove to a garage. They took apart the alternator changed some chip on it and said all fixed.
Three weeks later the same things happens. I take it back, they changed the battery for a brand new one and said all fixed.
Now a week later the same thing again. I paid over $500 and was without a car for almost a week in total, just to have the same problem a month later. The guys who specialize in auto electro told me that they can't find anything wong with the car - everything has been checked.
Any idea what I might be dealing with here and what's a good (any) way to find the cause ?
Also, what did the $500 cover? Most shops will warranty their work for 1 year so you shouldn't have to pay for the same problem in one month. Going out on a limb here, but are you sure they put in a new battery? Have you until this point been on the orignal battery?
Ken
The shop changed the chip in the alternator and put in a new battery (yes, brand new). I won't pay them again, the problem is that they will come back saying that the car is fine since the lights (and the battery dies) at random. I can be driving with everything on for 3 days with no problems and then I come back a day later be driving 20 minutes just for the battery to die.
If you have AAA, see if next time you can get it towed to the shop while the problem still exists, so they can see it.
I work in tech support for PCs, and I'd swear all computers work perfectly the minute I get my hands on them.
-juice
-juice
Bob....
-juice
Thanks in advance for any tips you can provide!
I replaced my MAS in response to a "ghost" stalling problem that would trip the CEL but record no code. After wasting several hundred dollars in fruitless diagnostics, a local indpendent Subaru mechanic suggested I try the MAS. I did - purchased a used one as my repair money was all but gone - and have had no problems with the stalling every since (5 years now).
Best of luck to your daughter. -Wes-
I'll see if I can find a used MAFS for her, and see if that does the trick.
Thanks again!
As it seems over the last few weeks I've been noticing that the car is getting lazier more and more when it comes to acceleration. Looks to me that the 1st and 2nd gear is not producing quite as good as it used to. In reality it really only kick in on the 3rd gear. What can be the possible causes ? Should I check the s.plugs (I don't think they have been ever changed).
I'd change the plugs, yes, but also the spark plug wires. The miles are very high, so if you haven't already I'd flush out the fluids (radiator, ATF or gear oil, rear diff oil, etc.).
-juice
On my Subie, a chipmunk, of all things, chewed up my wires to I changed those a short while ago.
Mine was misfiring, so I actually got a Check-Engine Light, but the tune-up fixed it.
-juice
Is there a guide available somewhere on the net that shows how to get to all 6 s. plugs and change the wires ? I'd like to do this one myself. Thanks.
The wires are easy. Just replace one at a time, right after you remove the old one. There are 6 and I believe there will be different lengths, 2 short, 2 medium, and 2 long. One of each length for each side.
Use the same path as the stock wires.
Haven't done plugs on an H6, but it shouldn't be much different than any other boxer. Access may be a bit tight.
-juice
I loved the car until 2 weeks ago
Check engine light is intermittently flickering on and the car is stuttering.
I can do 100 miles fine and then suddenly it all comes back.
The dealer has replaced exhaust, oxygen sensor, fuel filter and run a diagnostic.
Initial diagnostic showed oxygen sensor problem (replaced) and airflow sensor (not yet replaced)
Furthur diagnostics have revealed nothing - I think that the dealers think I'm mad! The car runs fine for them (on their limited test drives)
I am tearing my hair out!!! Please help
Power is stuttering so it's probably spark.
-juice
Interesting that you say the CEL is "flickering" on. I have never observed that behavior and was not aware it was able to simply "flicker." I wonder if that is indicative of something in and of itself? How many tanks of fuel have you run through the car in the past two weeks? Perhaps there is/was a little water in the tank. A bottle of Heet would eliminate that possibility.
-juice
Fortunately, last night I ran across a posting in a Mazda forum. They use the same NSK 6203DUL1 bearing for the idler pulley in the Mazda 6. So I called the local Mazda dealer, Spradley-Barr, Ft. Collins also. They knew immediately what I was talking about and said they get the bearing from Carquest Auto Parts and the number is 203SS. I called Carquest, 4 in stock, and have a better bearing that is the 203FF which is sealed both sides with steel. ~$10.50 ea.
BTW, they're easy to press out and in with a 6-inch vise and a set of impact sockets as the spacers. Loctite the bolts on re-installation. Now how to get the belt back on...
Hope this helps someone!
Theo
In cartoons, that's when the lightening bolts are coming out of the guys head! :P
:shades:
Be wary of head gaskets and oil leaks from the camshaft seals and/or valve cover gaskets. Otherwise, quite a decent car.
As for acceleration, mine does not pull real strong between ~35 and 50 mph unless I intentionally hold gears longer and accelerate aggressively, but I think this more a function of the gearing and shift points than it is a "problem" with something in the drivetrain. This engine can rev high with no problems though - max torque is achieved at 5500 RPM if I recall correctly, though I rarely take it that high as I am used to old vehicles like my '69 Chevy C20 (307) and there would be pieces of iron all over the highway if I tried that.
*Car has customized rims and low-profile tires
I believe eventually the car will re-learn itself if this procedure is not followed, but not exactly sure. Easy to do and I recommend it anytime the battery is disconnected long enough to start the lights flashing.
Anyway, considering no response thus far from the original poster, all must be well.
that--and yes--car was level! AND I'm a trained machinist! Am I human? Does being a cave-man count? Well...as far as the "check engine" light goes, she's had the same problem for years--the car will stall or sputter a bit then the light comes on and the car runs fine until the light goes off. 6 months ago she paid (without family knowing) $275.00 to have the light checked out and a crankshaft sensor replaced. Light comes on again 3 weeks ago, she takes it in--always to the dealer, they tell her "oh hey now its got 123K on it, you need all the valve shims checked and adjusted" (ain't they they hydraulic--wink wink??) and "the check engine light isn't the same thing it was 6 months ago, so its not covered under warranty--it's too technical for you to understand." All without family knowlege again... BTW car has been nicely cared for--will cruise easily at 90+++... I finally find out 2 hours after she says yes to a $1,400.00 estimate after they talk her into doing 4 more jobs, including tire rotation, a new key, blah blah... So I call, the guy says "oh yeah well we didn't do the valve shims 6 months ago when we had the valve covers off cuz nobody thought of it." So I also look at ALL the bills for last 9 years--looks like she's paid thousands for recalls. WTF??) All she wanted was her $4.95 oil change with her little coupon. One question is--in CA, would it be OK to ask them if they are commiting elder abuse without being sued for hurting someone's feelings?? So as I write this they called--the guy says "ohhh yeah those valves ARE hydraulic." I want to see a naked head and check with own eyes before I blow a gasket!! Hey Happy New Year and Good luck to all!!
That is unbe... well, nevermind, I have come to believe quite a bit to be possible.
Push it - perhaps contact SOA (800SUBARU3) and report it to them first, maybe talk to legal counsel if you can get a free consultation to find out what else you can do. Maybe chew out some higher-up at the dealership in a public place for taking advantage of their customers..... and definitely convince your mother to find a new shop or find one for her.
am i supposed to remove more that the pan?
-mike
ryan
-mike
