Chevy S10 - GMC S15 and Sonoma General Operating Questions
I have removed the two screws and the assembly is loose.
How do I get the assembly out so that I can replace the bulb
The TORX screws I see, seem to be for adjustment only
99 Sonoma Ext Cab
Mix in a wiper blade post when it started out seats and what not. How the heck do you follow through with this nonsense?
Any other Vehicle site I've ever been on, the original poster starts the topic, and non related posts are moved out or deleted.
It should also be separated by State.
Keep a General Thread, and have a Technical Thread, and Used Parts Thread just for S-15, Sonoma. And one for the ones with 4 wheel drive.
If so, turn signal if out on one side is always a bulb out on that side.
If all are out not working, then check flasher. Even if warning lights do work.
don
If you had temp and fuel before the engine work. You need to find out what is not hooked up, or what wire maybe pinched and shorted.
The switch is located at the key assy, follow the bundle of large wires to locate it. Be careful taking off the top cover with the hazard switch, it is easily broken.
don
http://i45.photobucket.com/albums/f98/gonogo/379910Ignitionswitchschematic_1.jpg-
Frustrated in Syracuse,
John
