Toyota RAV4 Wind Noise
                    Right away my RAV4 had a LOT of wind noise from the front passenger window, it sounded as if the window were not up all of the way. The dealer had heard of this with two other RAV4's and said that replacing the side mirror fixed the problem. They did that, and the original very loud wind noise is gone, but now I notice much more steady wind noise than I ever would have expected, and it's coming from both of the front windows.
I know the RAV4 is supposed to be good for minimal wind noise, but that hasn't been the case with my car. The wind noise is loud enough that you would think the car was 10+ years old.
I was about to go back to the dealership again, but thought I would ask here in case anyone else has experienced this. Thank you.
This will stop teh noise.
Did you find out where the problem is?
I'd appreciate any info you might have on this issue.
It's the rear view mirror on the passenger side that creates the seemingly wind noise.
It has a groove in the back that needs to be taped/removed or you can have the mirror changed...
It's a groove at the bottom of the passenger's rear view mirror.
Try put some duck tape over it...i did and the noise is gone.
What a relief!
Good luck
shastro
Took it to one dealer who decided to seat the window in the channel (didn't solve the problem - but now both windows are misaligned and catching when scrolling up and down). I'm taking it to a different dealer.
