Volkswagen GTI Transmission Problems
in Volkswagen
I'm the proud owner of a Red GLI (GTI clone) with the DSG transmission. I love everything about this car including the power, the looks, the turbo, the color, the seats, the suspension, the steering wheel, the leather, the satelite radio, the 17" wheels and of course the DSG with paddles. But since new it felt "funny" while changing gears, the shifiting RPMs would be different at different days. One day it was stuck on 2nd for a few minutes while the numbers in the dashboard flashed, and I always felt it would fail at any given moment. Eventualy it did and about 8 months ago at only 6 thou miles it would not go into reverse, and make terrible sounds while jumping from 2nd to 4th and then back to 3rd. with a terrible thomping noise and judder at start up.
The dealer replaced the DSG (after 3 weeks) and it has been mostly O.K. but still hunts for gears in a funny manner every now and then. The dealer says it is O.K. but i'm really scared if it fails again out of guarrantee and I will be stuck with a repair bill in excess of $6,000. I love the car more and more but I do not like living with this bad gutt feeling everytime I drive it, BUT I would hate to sell the car and find out it lived many years without problems. Besides I do not know what to replace it with. It now has 15K miles and It will be out of the guarrantee in three months. Any suggestions or similar problems?
Is it significantly higher than a standard automatic?
I own a 2008 GTI with DSG and have very rough shifting between gears 1, 2, and 3 frequently.
Was the advice you were given about flashing the ECU fix the problem?
i too have an '08 GTI w/ DSG... the shifting is kinda "jerky" between 1, 2 and 3... i find that when my wife drives it, it never happens and when i drive it slow or really fast it doesn't happen, but there seems to be this band of acceleration that i fall right inside most of the time and it jerks when changing gears... i'd be interested to know if flashing the ECU would fix the issue...
I got the transmission checked with diagnostic eqiup a month ago from the dealer and the settings came back normal.
I have yet to have the dealer flash the ECU but my next oil change I'll "turn up the heat" at the dealership and figure out how to stop the abrupt shifts - it's really bad at times.
They need to give me some kind of answer/solution.
The one that I am looking at is for sale here. It is the red one.www.DAngeloAutoSales.com
Is one with the DSG going to be a ton less reliable than a manual?
Another thing to keep in mind is that the DSG requires a service event every 40,000 miles whereas the conventional manual transmission does not.
Regarding how the two different GTIs drive, the DSG is a fast and slick shifting automatic transmission, and if that's what you're looking for, then this is probably the best transmission available in any mass marketed car available in the States. That said, I found the DSG A3 and DSG GTI I drove immensly boring once the novelty of the computer controlled transmission wore off (that took all of about five minutes).
Best regards,
Shipo
Have an '08 GTI 6MT
IMO the manual is more fun.
If you are going to be commuting in heavy traffic in this car I would recommend the DSG.
Don't know anything about reliability but the DSG transmission is much more complicated than the manual tranny, therefore more problems?
Are there other GTI owners who have experienced this sort of repair work?
They said the fluid is expensive???? and the Labor is also?????
They are not replacing any parts so this is pure bull.
The 2012 was hard to come by though, and the dealer I went through basically had to negotiate with another dealership to get one off the boat before it even reached the U.S. Anyway, if you can get a deal similar to mine I don't see a reason to get the '11 over the '12. Look up the Zag car buying service, it really helped get me a great price. I had access to it through my USAA membership.
