Hyundai Entourage High Pitched Vibration/Whistle noise
I have owned my Entourage since Septemeber 'o6 and I have about 10K miles on it.
When I travel over 70 mph I hear an intermttant, high pitched, vibration/whisteling noise. It is very sporadic and gets softer and louder. For that reason I think it might be air rushing through/over something in the van. I think it is in the front part as well. It also really doesn't happen unless I am going about 70 or over and how much it happens then just depends on the day.
I had my tires balanced and it still happens. The technitions also looked under the car for any loose material that could be causing the noise and everything looked fine. They also took it out twice but couldn't reproduce the sound. I will go out with them some other time when I have some time to actually do that.
I was wondering if anyone else has this experience?
When traveling up I-5 in Calif. traveling about 75MPH, I hear an eeary screeching sound. The wind was towards me at about 25MPH so the combined speed was around 100. When I slowed to about 65 the sound went away. No, it wasn't a siren for going too fast!! Anyone have similar noises?
Seems like it is around the windshield wipers arms.
Then noise will sometimes fade in and out or else be a constant screech - and can be VERY loud.
I have removed the wiper blades with no change in the problem. I do not have crossbars on the roof rack.
Since it is a highway related problem and I never hear it except when I have to travel it is impossible to get the dealer to experience the problem. So, I am just resigned to living with this thing! Other than that it has been a good vehicle.
Sounds like blowing across the neck of a bottle, amplified.
