Olds Aurora replacing egr valve
in Oldsmobile
Just found out that I need to replace my egr valve and that it would be $245, so now i decided to do it myself. What I want to know is how hard is it to replace the egr valve,is it as simple as taking the old one off and putting the new one in. The cheapest i found was at autozone, is that a good idea. The year is the 95 model
How do you know that your EGR should be replaced?
I pulled the EGR on my '97 last year to check for gunk buildup; it was amazingly clean. Replacement is fairly simple.
The experience of most posters to this forum is to use nothing but ACDelco replacement parts. I do not know the price for an EGR. Check on-line if you can wait a few days for delivery. RockAuto is good. I have no affiliation with RockAuto except as a satisfied customer.
Les
Replacing spark plug wires on the Aurora classic is not as hard as it looks at first, but it does take some time and patience. I have done the replacement once and am considering it again soon (the 100,000 mile interval claimed by GM is wishful thinking for the majority of us). I assume you will be replacing the plugs at the same time; use nothing other than ACDelco for plugs and wires.
I recommend removing the ignition module with the four coils attached. The '95s have a black shelf-like thing above the coils. I have never been able to find out what it is; no other years had it. I do not know if it will cause you a problem.
After removing the ignition module and coils, you will be able to reach behind the rear cylinder head to get at the spark plugs; you will not be able to see them. A socket set with a good complement of spark plug socket, ratchet, extension, universal, etc. will make the job easier.
Be sure to set the gap on all plugs. It may have been 0.050 or 0.060 inch for '95.
Good luck!
Les
