Mazda 626 Air conditioning troubles
When I put the gas to (or near) the floor on my 91 Mazda 626 (non-turbo) the air conditioning cuts off for a moment. However, lately it doesn't come back on.
Does anyone know what causes this?
The problem may not be the evaporator itself, but one of the A/C tubing connections. There is an O ring in every one of these and it can start leaking. Also, the connection B nut threads must be lubed with refrigerant oil prior to disassembly, otherwise it may be practically impossible to tighten the nuts enough to properly compress the O ring. There is a built-in shoulder in the tube, so you cannot squish the O ring even if you overtighten the connection. Oil on the threads prevents the possibility of twisting the tubing due to excessive force required.
The unit is fully charged... the compressor works when manually jumped... it will then blow cold air.
There is nothing in the computer code information that gives any clues.
There is some sort of relay or switch not doing it's job. Has anyone else run into this? I don't want to chase the proverbial needle in the haystack unless I have to.
Thanks in advance.
There are two switches (one high pressure and one low pressure - I forget which is which), but one is on the back of the accumulator. That was the culprit.
