Chevy S10 - GMC S15 and Sonoma Towing Questions
in Chevrolet
i just picked up a 1991 sonoma, 2.5l 5 speed, anyonw know what would be the max i could tow with this, i have a camper trailer that weighs about 3000-3500lbs, wondering if i could tow it safely
a. wind sail factor of a high profile in gust of wind
b. high profile is like pulling a parachute
c. stopping factor (electric brakes?)
d. overloading of engine and clutch
Being you have both, sonoma 2.5 and 3.5k lbs camper, start small and see how it goes. Hook it up and take it around the block. If that works ok, progressively increase distance. Watch your temp gage so it doesn't over heat. Watch your tac so your not burning out your clutch. Start out on level ground so your not getting pushed down a grade or over doing brakes.
In other words steady as she goes and see how it goes (or stops). Let us know how it works out.
Good luck
No Way would you tow a 3500 lb load with that size vehicle.
Unless you were just taking it to storage one time only and very little traffic on a Sunday morning.
This is where you see the news reports of people upside down and dead on the road and scratch their heads bald as to why.
1200 lbs at the very most.
Even My 00 4x4 v-6 can tell I have 2000 lbs back there and it gets sucked of power real quick on upgrades, so leave it out of overdrive if you feel very little gain in adding power.
2002 gmc sonoma 4x4 sls v6 vortec automatic, crew cab
