Visitor Agreement.
Good luck and I sincerely hope, for all KIA owners, you and others whom suffer from same mechanical problem, you find the time to file a complaint on the aforementioned web site as this is the ONLY way a recall will take place. Good luck to you and yours.
I am a stay at home mother of a 1yr old and the primary driver of this vehicle.Thank God it wasn't me and my daughter in the vehicle when this happened! As I am reading all these post I see many of them could have been a serious accident,not sure if KIA is just waiting for an accident before any action is taken to do something about this!!!!!! The KIA service department called the problem a pressure control solenoid valve,and would have to completely REPLACE the TRANSMISSION,it only took 3 days to replace BUT got it home and are experiencing a weird noise under the Sorento when going over bump, sharp turn, or just while driving sounds like something lifting and dropping back down sounds heavy! We are filing a claim into the Lemon Law with the BBB Auto Line. KIA Corp. contacted us and offered to pay a car payment for some compensation(sorry but thats not going to make me feel any safer traveling with my small child)The Dealer ship saying "this is the safest car on the road" is a joke.Corp also made the comment the Lemon Law doesn't apply unless the problem cant be fixed but we will see. We want OUT of this vehicle!!!So glad I found these post, The 2011 Sorento needs to be recalled before someones life is taken due to an un admittable prob. by KIA!
has anyone had any problems w/ the second transmission that was put in???
Can someone tell me, on which models the transmission problem occured?
V6, AWD, 4 cylinder, automatic or manual?
I was driving back home yesterday and when I got in the interstate, I noticed that the car was very sluggish. I also noticed that it wasn't going above 50mph, and that's even with the pedal floored. I then thought that I'd try it in manual and that did the trick. The manual shifting got me to 70mph with no problems. I noticed no noise issues or vibrations.
When I stopped at a traffic light on the interstate exit, I put it back into auto mode, and when I put the gas on to move forward, I felt a jolt and then I was moving again.
Can anyone tell me what's going on? I purchased my car used with 106K miles and now it's at 130K. 2005 Kia Sorento 4x4 V6.
What did the dealer tell you was the issue. I got the "we can't replicate the problem" speech from them today. I wish I could predict when it would happen again, but unfortunately, my crystal ball is broken.
How long did it take before they admitted there was an issue and replaced the transmission?
my 2011 kia sorento was fixed on recall regarding the tranny. After driving for 26 days I had a bad accident. It takes 20 minutes from home to work and I'm positive that the vehicle engine is in normal temperature. I stopped at MCDONALD REST. to buy my breakfast. the vehicle is facing towards the building of the restaurant. I got on and started my veh. step on my brakes to engage in reverse. the car started shaking, reversed and start spinning 360 degrees, hit the railings and the ramp of the restaurant and drive forward inrto the middle of the parking lot, and it stop because the two rear control arm (axles) were broken. I was shaken and it was hard to remember what really happened. what i explained was the same as what the witness saw while lining up on the drive thru to order her breakfast. The witness came over and helped me. The cost of the damaged was so expensive that I have to go thru my insurance. I had the vehicle fixed by reliable shop not Kia in order for me to verify that the accident was the result of the recall repair. The vehicle is drivable and I'm still waiting for some parts from KIA. I almost forgot that on that early morning before the accident the vehicle reversed on unreasonable speed on its own. I have to control by applying the brakes. My husband is driving the vehicle and he told that he is always alert everytime he backs up. I need your advice before i will informed KIA. Thank you very much, Nelda
Same problem. And me too it happened to my wife at first. I have a 2011 EX V6 AWD. It happened 3 or 4 times so far in 2 weeks. We had that noise and sudden stop when backing up from driveway. Then, when shifted to Drive, the car woudn't move forward on idle (just like it's on neutral), unless we press the gas pedal.
We took it to the dealer, and, like you, they updated the software. But it did it again (I knew it would, I had read your articles before).
But the last time it did that, we had a check engine warning. So we took it back to the same garage. They finally identified the Park Range Switch as faulty. That sensor sent wrong signals to the transmission control module.
I can't tell for sure this will solve the problem, because the car is still at the garage at this time since the part is B.O. Hopefully tomorrow I will have good news.
I have to put it in neutral ...turn the car off....restart it and place in drive inch it up a bit and then try to place it in park.
It happened twice today. Once when I parked at work and again when I came home.
I called Kia service dept and have an appt for next Tues Aug 7th.
I am worried. This should not happen.
I go back to the dreaded dealer tomorrow.
Hope that helps, the dealer was awesome. My only question is if they knew it was a problem why no recall???
I did have the same problem once with my kia sorento 2010. When I put my foot on the breaks, started the car, shifted the gear to drive, it went forward straight away with my foot still on the break. I was lucky nobody's in front of the car. Do you have an advise from Kia in regards to this issue.
Has anyone had this problem and if so how was it correctedd?
