88 Range Rover
I bought a used Range rover today and on my way home it started crapping out on me. The Oil Light came on so I pulled over and checked out the oil, it was full and fairly clean, so I started driving and then the vehicle started losing power. So I pulled off of the road and swung by a jiffy lube. The guy checked out the oil, said it looked fine so it must be an exhaust problem. So I went to another service shop and they said that it wasn't exhaust, but that the oil was not making it's way into the engine. He thought It might need a new oil pump and to flush the system. However, I can't find a parts house that can get an oil pump so I don't know where to begin. I just bought the car 5 hours ago.... I don't know what to do.... HELP!!!!
M
M
SUVs and Smart Shopper
M
An SAE and Metric socket and wrench set, and a can of WD-40 are going to become your best friends.
Not sure where you are located, but try to find yourself a good local Land Rover mechanic if you are not that handy.
Loss of power could be a bunch of things, from the oil pump to the fuel filter, to the fuel pump - heck it could even be water in your gas if you've got a leak in the top of the tank letting water in... There's too many things to list if you've got no more specific symptoms.
Get it to a mechanic and have them do a full once-over on it. Pay particular attention to frame, suspension (you didn't get the RR with EAS, did you?) and engine.
Best of luck!
/DA
I'm actually dreading whats going to happen long-term with my 2006 LR3 and it's EAS...
This is going to be hard for you, but take a deep breath. Remember it's a use car and they all come to us sick. I just bought my today and I knew upon purchasing it I will be putting some money into it to get the way I want it. You no doubt will have to go deep into your pocket, but check it pallie, it's a range rover! You are one the few, the proud to own the greatest off-road vehicle to ever hit the mountains. So think of it as a great investment. I know that's how I'm looking at mine. It will go to the grave with me.
Yeh, range rovers ROCKS
Peace always, and forgive my loud mouth?
