2008 Sienna Hybrid - Do you want 4 cylinders or 6?
Some bulletin boards speculate that Toyota is going to introduce a Sienna Hybrid in 2008. My question to the forum is this:
Would you rather buy a Sienna Hybrid with a 4 cylinder gasoline engine (better gas mileage, but less acceleration) or a 6 cylinder gasoline engine (lower mileage than the 4 cylinder option, but better acceleration than either a conventional 6 cylinder or a hybrid with 4 cylinders)?
What's your view?
What's your view?
I vote for a V6. It's already geared tall enough, all they'd have to do is eliminate idling when you stop and add regenerative braking. It gets 19/26 mpg now, so they could aim for 24/27 or so. That would be amazing for the amount of space it offers.
It's too heavy for the 2.4l to pull it up a long hill fully laden.
That being said, I will not buy the hybrid if it costs an arm and a leg. I will compute the $$ I save @ $3/gal, and if I need to drive the hybrid for more than 3 years to recoup the additional cost, I'll go with the V6 (This is the reason why I reject the Prius, too).
Lets have a vote on this. Right now we have 1-1.
What they do instead is have electric-only assist on the rear axle.
That eliminates a rear driveshaft and a rear differential, so the weight penalty is much smaller.
The catch is it's not full-time AWD. It has a temporary electric-assist on the rear axle if the battery has enough charge.
It makes a lot of sense to not mindlessly buy a hybrid without calculating the increased cost vs. the fuel savings. But some detailed analyses conclude that despite its higher purchase price a hybrid may in fact be cheaper overall for a large fraction of drivers.
The least expensive power would be from a conventional internal combustion engine of the smallest size, but in the US we demand high acceleration.
It is a misconception that a hybrid has no advantage on long stretches of freeway or on long grades. It does. Another version of this misconception is that a hybrid is only an advantage in urban traffic where the regenerative braking operates. The regenerative braking contributes only a small part to the higher efficiency of the hybrid. Regenerative braking only recovers about 20% of the kinetic energy of motion.
The big V-6 is way overpowered for long stretches of level freeway travel at legal speeds. It takes say 50 hp (or maybe less) to push a Sienna down a level highway at 70 mph. This would be more efficiently done by a smaller internal combustion (IC) engine than a larger one. Also the IC engines in hybrids are set up to operate in a very efficient part of the operating curve. That is, the engine controls are set-up to not employ the IC engine at low power demand, where it is relatively inefficient.
If you had a hybrid, there would be no reason to rent a vehicle for highway trips, even those with long grades.
The situation where the big V-6 would be needed would be 2-lane mountain roads in Arkansas or in the Appalachians where you might want to quickly pass slow logging trucks.
The 2.4l 4 cylinder could operate, say, at 4000rpm, where it makes its peak torque, via a CVT, but you'll end up using more fuel that way.
In other words you have 31% less displacement but you have to increase revs by less than 31% to end up using less fuel. 31% more revs than the 1600rpm my engine uses is just 2100 rpm or so. Can the 4 cylinder pull all that weight at such low revs?
I'm not convinced the 2.4l can effectively pull 4300 lbs, plus the full payload, plus the extra weight of the batteries.
I'd love to be proven wrong, though.
Driving at high power levels at constant speed in a low gear is done in racing where one needs instanteous acceleration or deceleration with slight movements of the pedal, but is ordinarily not wanted on the street because it is such a fuel waster. What happens in that case is that the waste heat going out the radiator and the tailpipe both increase dramatically, but the power at the wheels stays the same.
Section A-6 of this page from a NASA analysis shows a graph (Fig A-1) of engine efficiency vs. output power as a percent of max rated power. The efficiency is lower when the engine is at lower power and the efficiency rises as the power level increases.
Let's assume that it takes 40 hp to push a Sienna down a level road at 55 mph. If the engine is a 240 hp V6 then the engine will be operating at 16.7% of maximum power (40/240 = 0.167), and will be operating at about 22% efficiency according to the graph. If the engine were a 120hp I4, then the engine would be operating at 33.3% of maximum power and the efficiency would be about 26% according to the graph.
An increase in efficiency from 22% to 26% is an 18% increase in efficiency (4%/22% = 0.18), which is significant.
But is 40hp really enough? That number sounds too low for me.
We're not talking about an aerodynamic sedan here, we're talking about a big, boxy two-ton minivan.
I sort of doubt 40hp could sustain speed for a 4300 lb box. And remember, we haven't added the weight for the batteries and the hybrid drivetrain, so with payload we're talking possibly 3 tons to haul.
The 2.4l I-4 in the Camry hybrid makes less power than the regular 2.4l, and just 137 ft-lbs of torque at 4000rpm. So at lower rpm we're talking perhaps under 100 ft-lbs of torque.
You can get some battery assist, but not sustained assist, just an occasional boost.
Can that much torque pull 6000 lbs? Even if it was rated to tow at all, that's what a full hybrid van would weigh.
First the answer: Divide the speed in mph (speedometer) by the instantaneous fuel consumption in mpg (computer readout) and multiply by 12 to get the power in hp that the engine is making at that instant.
Example 1.
A Sienna is travelling on level ground at 55 mph and the fuel use from the computer readout is 27 mpg.
Q. What power in hp is the engine making?
A. (55/27) x 12 = 24 hp
Reasoning:
Dividing the speed in mph by the fuel consumption in mpg gives the fuel use in gal/hr. Since each gal of gasoline releases a certain amount of energy on combustion, this quotient is energy per unit time input to the engine. Multiply this by the efficiency of the engine (est 0.25) and you get the power output. We just have to figure out the conversion factor to kw and to hp.
Factor for kw = (1 hr/3600 s)(130 MJ/galUS)(0.25) = 9.0 kw per galUS per hr
Factor for hp = (factor for kw)(1.34 hp/kw) = 12 hp per galUS per hr
The 3600 converts hr to sec. The second factor is the energy content of gasoline in megajoules per US gallon*. The third factor is an estimate of the efficiency of the engine.
Example 2.
A fully loaded Sienna towing a pop-up camper is climbing a serious grade in Galcier NP at 50 mph. The computer readout of fuel use reads 8 mpg.
Q. What power is the engine generating?
A1. (50/8) x 12 = 75 hp.
A2. (50/8) x 9 = 56 kw.
*http://bioenergy.ornl.gov/papers/misc/energy_conv.html
A 6 cyl hybrid is like having the powertrain of the new Highlander hybrid on a sienna body. Maybe about 200 lbs heavier than the highlander but more aerodynamic. This will more or less provide similar mileage as the highlander hybrid.
I have a 2006 highlander hybrid AWD (old rating of 27 MPG Hwy and 32 MPG city). I drive 95% highway and I get 31 MPG on hand calculation.
Consumer Reports measured only a 1 mpg difference between a 4 banger and a V6 RAV4, yet the V6 performed much better. Is it worth a small (5%) gain in efficiency for a big sacfrifice in power and perhaps payload/towing capacities?
Basically, I think the 2GR 3.5l V6 engine is more evolved and efficient than Toyota's 2.4l for its given size.
Toyota should put the engineers that tuned the 2GR in charge of updating their 2.4l 4 banger.
My opinion is that a buyer who is interested in a hybrid has a greater degree of concern over fuel economy/the environment/conservation than an average buyer. The comment earlier was made that Americans like powerful cars. On average, that's correct. But the hybrid is never going to be successful attracting that average consumer. A hybrid vehicle shouldn't try to compete on power, towing, or acceleration. It's not going to be best in category, and emphasizing those attributes take away from maximizing fuel economy, an attribute where the hybrid excels.
Toyota's goal, probably, is to gain 3%, 4%, 5% (pick any number) market share in the minivan segment by having best in class fuel economy in that segment by a wide margin. I hope that they recognize that most hybrid buyers are willing to give up some acceleration speed in exchange for maximizing fuel economy.
One of the posters noted that Toyota's 6 cyl gasoline engines get about the same mileage as their 4 cyl. That's a Toyota failing that hopefully they will fix.
I'm interested in your opinion as to where my thoughts might be wrong.
The hybrid Accord (V6+electric) did not sell very well because they emphasized power over economy.
I just wonder if the 2.4l will really be adequate, and also if they can tune it better like the did the 2GR engines.
Maybe if they add Direct Injection technology to the 2.4l, it could achieve a better balance of power/economy.
The steepest freeway uphill grade in the US is <7% (actually the design rule says 6%). To run up 7% grade at 65mph, the power needed for a 6000lb Sienna(1600lbs for passengers and all loads) can be calculated as
0.07*6000lb*4.45(converting pounds into Newton)*65mph*0.444(converting mph into m/s)=54KW=72hp.
Adds to the 40hp at level ground, that's just 112hp.
Very "lossy" path, that.
What is needed is a variable speed supercharger that provides no "boost", only atmospheric pressure, in city stop and go traffic as long as the battery sustains a reasonable charge level via regenerative braking.
On the highway the driver would activate the "cruise" mode, maybe via the simple engagement of cruise control, and now the supercharger would be used to boost engine HP for acceleration or climbing instead of the hybrid battery being depleted.
The SC would be ICE belt driven but via an E-CVT. The opposite E-CVT input would be an low HP (3..??) AC permanent magnet synchronous motor using a(nother) variable frequency A/C solid state drive. The E-CVT would be used to control the speed relationship between the ICE and the SC, thereby having complete and total control of the SC's boost level independent of ICE RPM.
It seems even possible that the throttle itself might be replaced via the SC's E-CVT intake airflow control.
IMHO the 3.5l is well more than enough, so perhaps a smaller V6 would work? Something around 3.0 liters?
For how much can you purchase, wholesale, an electrically driven Prius/HH/RXh A/C compressor. That would constitute the major components, a variable frequency AC drive, and AC motor, and a compressor.
Manufacturing costs would be what, twice that..?
Light weight carbon fiber positive displacement SC?
You've consistently voted for the 6 cylinder-hybrid combination since your first post in June. Most of the engineers who have replied have had various formulas that conclude that even 200hp is more power than is really needed, even for climbing hills.
Remember that the hybrid engine WILL work simultaneously with the ICE. A hybrid does have two engines, pretty redundant if the electric engine could work full time. If you do need the power, the electric engine will kick in while climbing a hill and provide extra boost. In my opinion, it's a shame not to use that feature in order to downsize the ICE.
Your comments do speak to reality, however. There are some people who remember the sluggishness of the 4-cylinder minivans sold in the 1980s and 1990s. Convincing those consumers, and you, that a 4-cylinder ICE plus an electric engine is NOT equivalent to the old 4-cylinder minivans is probably a lost cause. No amount of information, either technical or advertising, is going to change your mind.
By the way, Bob Lutz, Vice-Chairman at GM, said that the Chevy Volt is likely to come out with a 1-liter, 3-cylinder ICE in addition to its electric engine. I have no idea what HP that converts to, but its not a lot. Yes, the Volt won't be a 2-ton minivan with another ton of passengers or payload, but it does speak to the over powering that we have gotten used to. The Volt is said to have 0-60 times of 8 seconds, which is enough for passing and merging into traffic. Yes, it won't beat the BMW 535 up a hill. But you also won't be able to buy today's version of the 535 in 2020 when CAFE requirement go to 35mpg.
In my opinion, I hope that Toyota comes out with a Sienna that maxes out its fuel economy potential. It may not suit every consumer's need, but it might be the best choice for consumers looking for fuel efficiency.
The 2GR 3.5l V6 blows it away in terms of fuel economy. No contest. It's also much quicker.
I don't see a reason to go back to a supercharged I-4.
Keep in mind that this would not be a LARGE high capacity SC, just enough HP boost to bring the ICE up to "snuff" for light acceleration or uphill travel. Passing acceleration would still require the hybrid "boost" aid.
Currently they run off of serpentine belts that leech efficiency from the engine even when you don't need the boost.
How would it disengage?
And if it did, wouldn't it partically block the air intake path? Or would you let it freewheel?
Even then, I imagine it would create a small amount of drag on the intake air while not under boost.
It just sounds incredibly complex and expensive.
Think of the ICE driving one end of an open differential and the electric motor driving the other. If the electric motor turns in the direction OPPOSING the ICE input then the output of the differential remains stationary.
So that's the basic idea, one input of the e-CVT (diff'l) would be belt driven via the ICE and the "opposite" end via the synchronous AC motor. In our case, as with the actual E-CVT, we would use a planetary gearset with a 3:1 ratio so that when the engine reaches 5,000 RPM the synchronous motor would be turning at 15,000 RPM.
To close the intake airflow and "choke" the ICE off the synchronous AC motor would turn at exactly 3 times the speed of the ICE (as it slows to 0) but in the opposing direction, the SC would therefore remain motionless and the ICE would be choked of all intake airflow.
No traditional throttle valve required.
Right now Toyota's hybrids are all Parallel hybrids, meaning that propulsion is achieved by both an ICE and an electric motor.
They need to move to a Series Hybrid, meaning that propulsion is provided entirely by electric motor, with electricity generated by an ICE (gas, diesel, hydrogen, nat gas).
This allows maximum torque to be provided by the electric motor at very low speeds as well as cruising speed. The on-board generator would not have peaks and valleys like it would if it were providing propulsion directly. Therefore, it can always run in it's most efficient range. This would also allow a much smaller engine to provide charging power.
This also is the ideal setup for the future, allowing plug-in capability as well as an easy change to alternative fuels as they develop since the ICE is not as significant a portion of the total car.
Ideally (especially for a van), the electric motors could be installed in the wheel hubs themselves, freeing up weight and space in a true one box vehicle.
The technology is here now, you don't even need the lithium batteries for this setup. They would only be needed in a plug-in scenario.
The VOLT is a series hybrid.
Whoever puts the series hybrid technology into place in mass quantities first, will take the lead in the Eco/Green/hybrid race.
Just my 2 cents worth.
But what about highway fuel efficiency? Doesn't a parallel hybrid get better mpg at highway speed?
One concern I see would be unsprung weight - you are adding mass to the wheels that bounce around each time you hit a pothole. It would be hard to tune that suspension and the shocks would be working overtime.
It certainly frees up packaging tremendously, but car makers use light alloy wheels for a reason.
Another concern is the electric motors would get wet in puddles, and would be exposed to the elements.
The current Sienna averages 19mpg according to the EPA.
Come on Toyota. Give us a more efficient van for our families!!
Exactly how much safety are you trying to achieve? What exactly are you wanting to protect against?
The Tundra is RWD and therefore will be significantly safer in overall operation on adverse, ice or packed snow, roadbed conditions.
Yeah, I've heard rumors ranging from 2010 MY to 2012 MY. Like the other hybrids, it's likely to achieve real MPG gains only in stop-go-stop-go-stop-go traffic conditions (i.e. where the ICE can shut off). Since the ICE is still needed to push it down the road on the interstate, highway MPG isn't likely to improve much,
Well, not really. With the "electrics" along to act as an ICE SuperCharger the ICE can not only be downsized (lower frictional losses), but made more efficient at fuel "burn" using the Atkinson Cycle technique or simply derated as in the HL and RX.
if any, over what it is now. No matter how you look at it, it's still a 4,000-pound vehicle with a 3.5L 6-cylinder, not a 2,500-pound Cavalier with a 2.2L 4-cylinder. More liters drink more fuel. :sad:
[/quote]
"..with a 3.5L 6-cylinder, not a..."
That's the point, or at least partially so...
The turbocharged 2.3L I4 in the Acura RDX produces 260HP....
Think about what could, MIGHT, be done with a hybrid 2.0L I4 using the Miller Cycle via an engine driven Supercharger. But with the positive displacement composite (carbon fiber) SC speed/boost controlled independently of the engine RPM using the Toyota HSD CVT concept. During hwy cruise the ICE would just "loaf" along with the SC providing enough, "just" enough, the exact right amount (NO throttle plate), of intake airflow for the level of engine performance required/needed.
Okay, now put your foot "into it", the lightweight carbon fiber SC spools up virtually instantly putting the ICE "on boost" and the electrics "kick in" their extra TORQUE.
Zoom, ZOOM,....ZOOM...!!
And all with absolutely STELLAR FE.
Now just add a CNG conversion kit w/tank (carbon fiber) and refill the CNG tank overnight at home using PHILL.
Using CNG (~100 octane equivalence) would not only increase the "standard" ICE's HP/torque substantially, but would allow the compression ratio to be increased to an even higher level..
Maybe we wouldn't need a LARGE 2.0L ice, maybe a 1.5L would suffice.
It should.
The Camry 4-cylinder (2.4L) gets 155hp. As you noted, the 2.3L Acura turbo charged 4-cylinder gets 260hp. The Acura TSX without a turbo gets 207hp.
When I first started this thread, I was hoping that SOMEONE at Toyota would focus on a highly efficient large vehicle. The Highlander falls short. And as Atexeria pointed out, it would not be for everyone. If you need to tow something, don't get a hybrid. If you want good acceleration, get a Highlander hybrid or don't get a hybrid.
As they did with the Prius, would Toyota make a large vehicle that focuses on fuel economy. The Prius has a 1.1% market share of all vehicles sold in the US. Every other hybrid combined also has a 1.1% market share.
Fuel efficiency doesn't turn everyone on. But if its very important to 1% of the new car buyers - one's with families -
Come'on Toyota!! Let us have it!
They've been lowered twice, yet CAFE still uses the very outdated higher numbers from the 1980s.
The Sienna would probably get 23-24mpg on that old scale.
Yes, that's likely very true for I4/inline, but what about "boxer" style..??
Wouldn't those be even more "perfectly" balanced vs any "V" engine..??
It's worth the trade-off for all the extra horsepower, but still.
FWIW Toyota added sound insulation to the fire wall and along the door sills to offset the extra noise from the V6.
Hybrids often shave weight by removing sound deadening, though.
http://townhall-talk.edmunds.com/direct/view/.eea4ead/1223
Can you please hop over there?
Does any one know if this means no hybrid system for the Sienna?
