Volkswagen GTI Tire & Wheel Problems
                    I just bought a 2007 GTI. It comes with the 17" wheels and summer performance tires.  I live in NYC.  Will I need to buy a set of winter tires for the snow?  Any suggestions would be appreciated?
i have had great luck with discounttire.
even "all" season performance tires are a joke (i speak from many years of driving on them)
just my .02
I'm considering having the dealer fit 17ins as long term i'll take ride quality over the extra performance.
Any similar experineces?
It's true the salt on your alloys is a separate issue but I've been really impressed with how this car has handled the snow this year.
Thanks, Waddy
So after 8200 miles my '08 GTI has had enough of it's summer tires. Took it in because the tire noise was getting progressively louder and the tech says they have very bad "cupping". Of course not covered under warranty. Anyone have better luck with their non-summer tires?
Best regards,
Shipo
I can't think of many places where I'd want to run low-pros, no matter how nice I think they look, just because of that.
A few years ago my brother was shopping for a new car, and the dealer showed him a car that someone had ordered but decided not to take. It had large wheels and low-pros and the dealer offered to not charge my brother the cost of the option in order to move the car. The car looked great with the wheels and tires, so he decided to take the deal. He lives in north NJ. Within two weeks he had gone thru two tires and was going to have to replace a wheel along with the second tire because of rough road conditions. He changed out the wheels and tires to something a little more normal in aspect ratio and decidedly "less cool". But the roads stopped eating his tires.
His "free option" only cost him almost $2000
On most of my vehicles I've rotated every 6000 miles, although on one current one that tended to develop cupping on the original tires, I rotate at 5000 miles.
Thanks for your ideas.
1) Impact wrenches, by the nature of the beast, "hammer" whatever they are torquing in place, and when using them on a wheel, especially an alloy wheel, they are guaranteed to screw things up royally. Lug bolts need to be smoothly hand torqued in place, period, full stop, the end. Said another way, any tire shop that uses an impact wrench on tires is a tire shop that will not get my business, ever.
2) If they're only using fifty pounds of torque on lug bolts, then the cars they service are in serious jeopardy of finding themselves running down the road on three or fewer wheels.
I'm thinking that you might want to call around and find a shop that hand torques the wheels they mount.
Best regards,
Shipo
Thanks again.
Dok
Yokohama Advan S.4. -- $180
Bridgestone Potenza RE960AS Pole Position -- $167
Michelin Pilot Sport A/S -- $206
The above said, I'd move the Michelin entry to the top of the list if I needed to drive in winter conditions (I do and those are the tires currently on my car).
Best regards,
Shipo
Yesterday, on 12/17, I heard a rumbling, pulled over, and found the lugs were coming off. I put the car up on the jack (in freezing cold), used my 3-ft wrench extension, and torqued the lugs to more than before.
I'll check them again and hope those stud bolts will stay in, but seems to me there's something wrong with VW supplying a wrench that won't take off a lug when there's a flat or need to change, and won't torque the wheel tight enough. I live in the northeast and travel to the mountains in winter, so can't afford flighty tools and instructions.
Here in the north, I found it necessary to downsize the drive wheels and put on soft-rubber snow tires, which are seeming to work well in snow.
Someone else should know more than me about what a summer tire is.
1) Are all 18" tires low profile?
2) Are 17" tires more pothole friendly?
3) What is the fastest land mammal? :P (Airplane II)
Thanks much
1a) No, but in the size that properly fits the GTI, yes, they're low profile.
2q) Are 17" tires more pothole friendly?
2a) Assuming the identical outer diameter of rubber, yes.
I'll leave question 3 for others to answer. :P
Best regards,
Shipo
2). I would imagine that 17" tires are more pothole friendly. They are generally smoother riding, as well, not as "sporty." My car came with 18" (2007 Farhenheit). If I had it to do again, I'd go with 17" tires. This is simply personal preference.
3.) Cheetah!
From the looks of the past messages, I'm going to go for the 17" wheels due to the feedback from all of you. Thanks for making my decision wise and practical.
