I mention the right hitch. Make sure you get a hitch with enough tongue weight capacity. I have noticed several aftermarket hitches that I've looked into with only 300 pound ratings. I'll probably spring for the GM accessory hitch, as it's the only one rated at 400 pounds that I've seen so far.
I haven't towed anything with our Torrent yet, but I did tow my 12' popup (17 feet from hitch to rear bumper)once with my sister's Chevy Venture, and it wasn't a very satisfying experience. Of course a big problem there was how narrow that van was, and how the trailer whipped the van around more then I felt comfortable with (tail wagging the dog), as compared to my Chevy Astro with the 4.3 (which tows great!).
The Torrent being wider and not as long, I'm hoping it will be more commanding of the trailer then the Venture was. And also with the 5 speed, I think it'll have an easier time keeping the engine power in it's sweet spot then the Venture did.
I just bought a 10ft pop up weighing in at approx. 1600lbs our first trip is coming up but towing from the dealer home seemed to be a breeze, and little trips around the block to get use to it were no problem.
It was easier to tow the heavy trailer than a little storage box on wheels which I felt every little bounce, but the heavy trailer was pretty smooth. The hitch I put on is rated for 3500lbs which the truck is rated for so why go any higher. The hitch is called Hidden Hitch with weight transfer ability meaning it could transfer approx. 500lbs of weight to the front if the back end of the truck sags to much.
hope this info helps, after the big trip I will let you know more
