Toyota 4Runner Warning Lights and Gauges
                    Hello-
I have a 2003 4Runner with about 50k miles. All at one time, the check engine, VSC Trac and Trac Off lights all came on at one time. the car seems to drive fine. Do I need to get it serviced? Anyone else come across this?
OL2 sensor heater control circuit low.
Wiring harness to 02 sensor shorted to body.
Repair wiring harness.
Regarding the VSC and Trac Light:
Decel Sensor undone.
Recalibrated decel sensor.
I hope this helps.
RUD1
All help is greatly appreciated.
Coolant and resavoir is at the proper level, belts and fan are working properly. Upper radiator hose is hot but not extremely. Lower hose is cold which indicates the thermostat has not opened. I can not locate temperature sending unit. Looking for a diagram and any information you can give, Thanks
Just a thought!
I'm having the same issue, I will appreciate if you can tell me what happend to your vehicule.
Thank you :sick: :confuse:
My miles now is around 75,ooo
any thoughts?
Also make sure the parking brake lever/pedal is released completely.
I have driven the car like that for 4 years and the car always runs good. Several mechanics told me not to bother with trashing money at the dealers. The only problems were that red light on the dash, it can be distracting at night and I had to pay about twice the cost of inspection every year. After I spent a hundred dollars for inspection last year I decided to do something about it. I started to research online and within several forums, several contributors said they work or used to work for Toyota dealers and that most of the time the problem is caused by the Mass Air Flow Sensor (MAF), and it is easy to clean it to fix the problem. Some forums even document step by step, with pictures how to clean the MAF.
To make sure the MAF is causing the problem you need to get you car scanned and get the error code. If you get P0171 System too Lean (Bank 1), then it is definitely the MAF. Most Auto Zone will scan your car for free. But I decided to buy the device instead from amazon.com: (Actron CP9145 AutoScanner Diagnostic Code Scanner with Live, Record and Playback Data Capability for OBDII (Post-1996) Vehicles) . The device is easy to use. I got the code, I followed the instruction on how to clean the MAF found here: http://www.4x4wire.com/toyota/maintenance/tacoma_4runner_30k/maintenancep5.html , and I have not seen the CEL again since that time. I hope this help.
Now, there's another strange thing going on with my 94 4Runner 3.0 V6. Now sometimes when I make a right turn, especially when I do so at a green light (not stopped), my 4WD light will flicker real fast and make a "clicking" noise. No drivability issues have sprung up, it's just the light and noise. The flickering noise stops when I finish the turn, and doesn't happen every single time, but about maybe half the time. What do you guys think?
Amy
I have an 01 4runner V6 w/ 261K miles. These lights came on in Cape Hat as soon as I got off the Ferry. After about 1K miles they turned off again....7 months ago I had the left side of the engine rebuilt due to head gaket I think for $2700 and the lights remained on...Mechanic said they will turn off after I replace the o2 censor so I did'nt worry about it then. Now I've attemped to get the emmissions inspection 5 times. The first time it flunked was due to 1. Misfire on cyliner 1 and 6. 2. Faulty o2 censor. 3. Collant censor or something like that...This cost $500 to repair and I was told to drive the car 50 miles before I had it retested so after 50 miles it still flunked due to the "Readiness". I was told by Jiffy Lube to drive it another 50 miles and bring it back but would have to charge me $25 again, I said I would drive it 100 miles to make sure but they insisted on only 50, so after 50 they took my $25 and rejected me again for "Readiness". After about 150 mile the lights came back on again...This time it was rejected due to "Random Misfires" and the Check engine light. It appears the misfires occurred while the car was sitting still and rpms were at 0 ( Zero) The mechanic couldnt figure out anything as his diagnostic showed zero misfires while idling, while driving and while reving the engine with the brake depressed....I unhooked the positive cable to the battery at my friends request and the lights went off....Yesterdays inspection failed due to "Readiness" in 2 areas, "Cat Converter" and I think the fuel system or something...Any suggestions would be appreciated! The truck runs great but I cant get a tag for it... fieldsws
I started by removing the plugs and discovered that spark plug wire #6 was broke, so I replaced the wires on the right side of the engine, which connect directly to the coil packs on the left side of the engine. I've never seen a system like that but it was pretty simple to do. And while I was at it I had bought and replaced the fuel filter just in case. Vr. Jerry
Last evening I got in and started it up ... and my gauges were dead. All the dash lights work just fine but the SPEEDO, TACH, FUEL, and ODO are all dead. By 'dead' I mean they just sit there as if the car is off. SPEEDO, TACH, and FUEL don't move at all, and the ODO is just a blank solid gray LCD screen. Strangely, the TEMP gauge appears to work just fine. All the exterior lights appear to work correctly. There has been no work done on the vehicle recently to have disturbed anything.
I haven't had an opportunity to check the GAUGE FUSE yet (I hope it's that simple) but I was wondering if anyone had any previous experience with this problem?
Thanks !
