Pathfinder Fuel Pump
I have a 2004 Pathfinder SE which has had an intermittent problem with squealing belts. The issue started approx 2 years and I have had the car serviced 4 different times. The problem was initially diagnosed as a CS belt/pulley problem and the first the belts have been reset then replaced, then the pulley was replaced. After each adjustment the noise would stop for a variable period of time and then recur. The service center performed these services for free as the problem was first diagnosed while the car was under warranty.
Now the service center says the squealing is from a broken power steering pump. They further state that it will not be covered by the warranty since this was not the problem initially and the car is out of the warranty period.
My question is: is it possible that this was the underlying problem initially? Is it reasonable to think that a similair squeal recurring over the course of 2 years is the same issue or is this two distinct problems? How would I differentiate? And how do I know that the fuel pump was even checked during any of these other visits.
I will also like you to send a complaint certified letter to the CEO of Nissan USA. I did that and I had someone call me within days. The more we compain as a group, the better chances we have at getting this defective part recalled. :sick:
