Hyundai Veracruz Oil Filter Design
I've changed my oil for years. However, I have read that the Veracruz has a different type filter than what I'm used to. I checked Fram's website- it looks like the filter comes without the metal casing. Is this system owner-accessible or am I going to need to use a dealer for simple oil changes? This is my first Hyundai. Is this typical for the brand? Any guidance would be appreciated.
Craig
'07 Santa Fe(about to be replaced by Hyundai for a Non-Lemon law Arbitration ruling)
Let the dealer do it and worry about oil filter and the design. It also documents your oil changes when you sell it.
In my opinion, changing ones oil is false, risky economy.
Autozone has the element style filter for about $8 bucks.
STP S9999.
My 2¢
My $16.42 worth ! @ $3.00 per gallon!
Also, where did you get your filters? Do they have them say at Autozone or do you have to get the filters and crush rings from the dealer?
Thanks in advance.
JIM
I get the Fram filters from Walmart, the crush washer from the dealer in quantity).
I'm not sure if your filter design is the same as on mine - 3.3L v6 but if so, it takes a little getting used to it. The filter 'cage' just snaps out by pulling - this isn't obvious at first and then the new one just snaps back in place.
Best luck... Roger.
Thanks for your time.
JIM
I think the filter is a Fram PH9999 and it comes with both o-rings. The crush ring is for the drain pan bolt - I'm still using my original one actually with no leaks/issues.
JIM
I ordered a cargo tray, touch up paint and 3 filters from them. They shipped very quickly and offered discount pricing for first time customers.
I tried a 93mm last night - but didn't fit correctly - seemed close, but it wasn't anywhere near deep enough to fit over the cap.
Per the attached link above includes grades SL and SM with SM being the newest.
http://www.burkeoil.com/pdf/oilguide.pdf
Wal-Mart here in Alabama has them for $6.00 that includes the two separate "O" rings.All o-rings go in the filter assembly, not the drain plug.
The Fram filter is made in Korea and looks identical to the OEM one including the green built in "O" ring.
Refill capacity with a filter is 6.76 US quarts.
Filter cap tightening torque is 18 ft/lbs.
Oil drain plug tightening torque is 32.5 ft/lbs.
Not sure of the oil filter cap "wrench" size but the special service tool from Hyundai to fit the cap is part number is SST092633C100.
If anyone locates an after market "wrench" please advise.
(torque at 32.5 ft.lbs.).
The oil filter housing was easy to remove by just using my hands, no filter wrench needed. I used Mobil 1 5W30 (6.4litres). Love the oil filtration design, it makes less of a mess. very similar to my bimmer.
Keep on Veracruzin'
The manual states 6.76 US qts with filter change. 5 1/4qts will score the dipstick spot on after running the engine following the oil change to refill the filter housing.
The dealer changed the oil one time and overfilled it buy 3/4 of a quart.
Oil checking ALWAYS done on level ground with cold ( overnight) engine.
Anyone else had this problem?
Do dealers overfill on a regular basis?
TIA
Here is their web site.
http://www.asttool.com/front_page.php
They are located in Boulder Co
If you remove the plug, then the filter, drain the oil, replace the plug, replace the filter and refill the oil, you will need 6+ quarts of oil.
Some technicians do it the first way, others the right way.
Also, if the engine is cold, it is unlikely all the oil will drain before the plug is replaced.
According to Hyundais service site:
Capacity
When replacing a short engine or a block assembly :
6.0L(6.34U.S.qts,5.28lmp.qts)
When replacing an oil pan only :
5.5L(5.81U.S.qts,4.84lmp.qts)
Drain and refill : 5.2L(5.49U.S.qts,4.58lmp.qts)
Their drain and refill says 5.49 qts, which is what I put in when I just did an oil change, but was barely registering on the dipstick, so I recalled this site and saw 6.76 Qts, so I poured in the rest of the 6th qt, now I am about a 1/4" above full.
I pulled the drain plug, changed the filter, then reinstalled the drain plug with a warm engine.
As far as the filter goes, this design seems sloppier than a spin on only due to the fact you have to replace the o-rings, plus the additional time to remove/replace the engine cover.
Just my .02
Has anyone else run into this and more important have the correct Fram filter #?
I believe the problem is your dealers "oil change" back in May. Does your dealer sell brands other than Hyundai ? If so the 19 year old pimple faced oil change dude probably screwed up.
If so no big deal you just went several thousand miles with no filteration.
Just one more reason to change your own oil.....
Ken
charlie
synthethic oils 5,000 plus per change
the cost difference is balanced with changing my own oil. I purchase oil from advance when it is on sale I purchase 5 quarts and they give me a filter yes I will have to purchase the extra quart.
Question?
Which oil do you use my dealer uses Pensoil? Whay oil does Hyundai recomend?
charlie
First oil change synthethic castrol and used CH9999 filter found at auto zone. Yes I replaced with 5w-20 synthethic oil
total oil and filter $36.48
labor priceless.
charlie
ASE certified Technicial and High School Automotive Instructor
Understand Mid-08 veracruz changed oil filter design/size but i'm finding different info. that suggest either the filter being suggested is of the old type or just no record of a new filter & corresponding number.
National auto store suggested Purolator L-35610 but Purolator itse;f suggests L-25848.
Has anyone changed oil on a 2009 Veracruz and what filter (please describe numbers) did you use?
charlie
And maybe you should email Hyundai? Or try the Hyundai web tech page?
