Chevrolet Cavalier Check Engine Light
                                  in Chevrolet
                    so i drive a 2000 cavalier and the check engine light has been on ever since i bought it 2 years ago.  and i took it to a car place to get it diagnosed and they said there could be a vacuum leak but they never found out where and it is causing me to have very bad gas mileage. so if anyone has had a similar problem to mine i would appreciate your help.
I drove my car for a week after getting the car fixed at Midas (fixed my exhaust system - new converter) and come to find out that for some reason my Brake Fluid Cap was loose/almost off! The reservoir for the brake fluid wasn't empty but it was close!!! I don't know if the ABS Pump is out now or what? I have had my car scanned several times at Checkers for free and nothing shows up! They say the Check Engine Light must be on to have the computer show a code.
If anyone has a solution for this or anything would help!! I have found a different discussion about this problem with a Grand Am GT but nothing for my car. I have a Cavalier Z24 2.4L
Please HELP!
The ABS coming on above 15 MPH is usually a wheel sensor.
I said no thanks, and when I asked for the error code he laughed at me and told me that their state-of-the-art-bad-[non-permissible content removed]-scanner is not like the one from Auto Zone, and there is only some generic code which won't mean anything to me.
After spending some time online I found a lot of things that could cause this:
wheel hub assembly/bearings, wheel hub assy harness, speed/ABS sensors, low break fluid, ignition control module, loose fuel cap, fuses, and now... ABS control module.
Where should I start?
Don't places like AutoZone run a scan of your car for free? I know they used to but I haven't needed that service for a long time.
I love my car ,but the light thing is out of hand. Cost me $90.00 to find out :mad: loose fuel cap, you need to turn the cap 3x's or else SURPISE LIGHT ON $$$. CODE PO440. I Hope this helps? :shades:
PS CAR IS A 2000 CAVALIER 2.2 WITH 95 THOUSAND MILES :confuse:
I have a 2004 Chevy Cavalier, It has a 2.2 liter engine, and i was wondering how many O2 sensors it has.
My reason for asking is because I would like to know if it is possible to connect a voltage adder to the vehicle to make the computer thing it needs to lean out the fuel.
Here is a link to a site that shows the device i want to use in my car > http://www.youtube.com/watch?v=jgHJDD6UK0A
and here is a schematic for the device http://www.madcosm.com/apps/photos/photo.jsp?photoID=2021606
I dont intend to use the oscillator if i dont need to.
So basically i would like to know if i can add voltage to the 02 sensor inorder to make the ECU lean out the fuel?
Thank you for any tips or advice you can send my way!!
Also, it starts kind of hard when the engine is warm. I live in northern MN and when it's -30 out, it starts right up. If the engine is kind of warm, like say I went to Target for 30 minutes and got back in the car on a nice 50 degrees day, it would start hard. Usually I get it to start by pushing the gas pedal to the floor before starting, or giving it a little gas while it is turning over (if I forgot to push the pedal down before starting).
ANYWAY... now when the engine is warm, it is still starting hard, but temporarily the check engine light flashes. The whole car shakes and kind of smells like exhaust. I've tried letting it idle for a bit, giving it a little gas while it's idling... sometimes it works, sometimes not. Sometimes shutting it off and trying again works. Sometimes not. If I am not in a position to shut it off and try again the light stops flashing and goes back to just being on steady after 5-10 minutes. But the car is shaky whether idling in traffic or while actually driving. The shaking stops once the light stops flashing.
I plan to bring it to the mechanic this week but in the event that it doesn't misbehave for him like it does for me (which is the norm) WHAT IS GOING ON? If it is a quirk I have to get used to, fine, if not, I don't want to make the car worse by letting it go. I have had this car since I was 16 - I am 22 now - and it has been an amazing car, I know its quirks, and I am hoping to hang on to it for awhile longer!
ITS A LITTLE RED BOX AND IN THE MIDDLE HAS A ARROW POINTING DOWN....
WE FIGURED IT WAS FOR SOME KIND OF LIQUID THATS LOW SO WE REFILLED EVERYTHING WE COULD THINK OF....
BUT ITS STILL ON.
WHAT IS THAT RED LIGHT?
i took the speakers out of the car to see if they worked and they do work, and i used a voltage tester on the wiring up to the front speakers and im getting a reading but since the airbag went off in the collison[before i bought the car] im afraid to take the dash off... what can be done to the cd player? and can i reset the check engine/trac off without taking it to a shop? :sick:
Replace the TPS (Throttle Position Sensor). $30 to $40 if you do it yourself or $70 to $95 if you have a service station do it. Of course you can pay a dealer to do it but they will charge you hundreds of dollars, (just my opinion).
This will fix all of your problems related to the TRAC OFF light and transmission shifting into low gear.
P1137 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Lean System or Low Voltage
P1138 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Rich or High Voltage
P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P0137 - O2 Sensor Circuit Low Volts (Bank 1 Sensor 2)
P0138 - O2 Sensor Circuit High Volts (Bank 1 Sensor 2)
P0140 - O2 Sensor CKT No Activity (Bank 1 Sensor 2)
P0136 - O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0300 - Random/Multiple Cylinder Misfire Detected
any help with be greatly appreciated, i need my vehicle for work....
Good luck
cable goes to the right side of the engine (stud sticking out of engine block) also the 2 wires from the main harness also hook to this stud, they were corrected a little, snipped them off put ona new connector and HOLY CRAP this car never ran this good, no propblems or lights on since.
its like $90 bucks.
its worth it. will repair a headgasket that is blown ( not fully blown but worth a try since theres a money bak guarantee. have a mechanic put it in. I did to mine. thanks
