Chevrolet Camaro Engine Problems
does anybody know about this engine and it's computer? i have done everything that u can do to an engine but it won't start! the code reader say's it should run but it won;t!! any advise would be appreciated!
Now, today, when I turned on the fan to run the vent-air, I hear a fan noise. The motor on the passenger window has been broken for over a year.
Now, I worry about driving the car. Certainly do not have the funds to pay for major repairs. Any ideas?
Codes: P0300, P0449, P1120, P1561. Replaced egr, what else should i do?
also looks like one of those codes indicates throttle position sensor. malfunction of that sensor could account for the symptoms too.
some of repair/replacement of the gasket is probably is done with RTV sealant, it's not easy to get a good cure/seal, took my dealership 3 tries to get it sealed right.
personally i wouldn't run that engine whatsoever until it's fixed.
ps - Lately I'm thinking 2012 Camaro ZL1 - with no engine problems.
theoretically the symptom sounds like it can be explained by gasket/flange/fuel-line failure-when-heated on the inbound side of fuel pump - failure allows air into pump intake rather than fuel.
if that's the case the fuel pump may have irreparably damaged by running too hot due to no 'fuel pump coolant' (fuel).
if pump/fuel-line is difficult to access, a way to test the possibility may be cold-spray to chill-out the suspect areas/items to see if that delays the issue from occurring.
