Honda Civic Hybrid IMA Problems
2456730
  • babootbaboot Member Posts: 3
    Thanks to everyone for sharing their issues about their HCH. I joined this forum to find out about my recent problem with my 2003 HCH IMA.
    The IMA light came on during a recent trip over Christmas (250+ miles). It came on while I was running low on gas and the "gas pump" indicator light was showing for about 15-20 miles (I have run with the gas indicator light on before with no issue and my IMA is probably not related to the low gas but I thought I would provide the information).
    After checking in the owners manual I made an appointment with our local Honda dealer a few days after the IMA light came on (and never went off by the way). I have just returned from the dealer and I was told their tests indicate "the IMA battery system is bad and it needs to replaced at the cost of $3785".
    Not pleased I asked if driving the car in "this condition" was a problem, and they said no but you may have decreased performance issues, I walked out without ordering a new IMA battery system. My gas mileage has been regularly around 45+ mpg, but in the last couple of weeks it has dropped to 41-42 mpgs. I am unsure if the IMA issue is to blame.
    Concerned about not knowing enough, I googled the problem and I found this forum and here I am. After reading many issues with HCH IMA, particularly for 2006 HCH, I sense that my need to replace the battery any time soon is not a priority (perhaps I am wrong). I also see I may need to take it to my local corner gas station mechanic who is damn good, and have it put it on his computer so I can get a "second opinion". I should have taken it to him for the first opinion but I guess I was worried about the IMA system problem being too complicated for him.
    My plans. I am not going to replace the entire IMA battery system unless there is overwhelming need to do so since I do not want to spend almost $3800.
    1. Any thoughts from the forum members about the need (safety is my obvious concern) of having to replace the IMA battery system soon?
    2. Can I drive this car, even if the IMA totally fails and use it as a just small gas engine car but with a reduction in mpg performance. There must be reasons this won't work as it seems too easy.
    3. Are there "fixes" either I can do, or my mechanic can do such as: charging up the IMA system when parked (running the RPM to 5000 for several minutes as I believe someone suggested); driving the car and making sure I charge up the IMA by "coasting" down hills as much as possible; other ideas???
    3
  • MB_in_MNMB_in_MN Member Posts: 18
    We have a 2009 Hybrid, and the IMA light came on. The report from the dealer was that the battery was bad, and needed to be replaced! (Seems a bit premature; have had the car about three months!) The part is backordered, and could be 3 - 4 weeks. We know of one other local owner with the same problem. It was replaced, and then the replacement went bad a few days later. Even the dealer mentioned the word "lemon."
    We have been fortunate with our dealer. They gave us a free rental (new Civic, non-hybrid), without any questions.
    But this suggests that there is a problem with this component. And from reading the other posts here, it is not a new problem. How do we get Honda's attention?
  • grandtotalgrandtotal Member Posts: 1,207
    I'd say you already have Honda's attention. Sounds like you have a dealer who is working with you. If I were you I'd wait as patiently as I could for my car to be repaired then drive it. I expect that there is a good chance you will not have a recurrence. If you do then that is the time to look at what to do next. In the meantime it would be sensible to make sure you document what happens, just in case.
  • tonitotonito Member Posts: 4
    You most probably have not much option, other than replacing the battery.
    My HCH 2003 started with IMA and Check Engine lights turning on very frequently (like 20 or 30 miles after resetting the computer). Several months ago it was not so frequent.
    Gas mileage also gradually has dropped from around 45 to 42 or less.
    I had to take it to the Dealer, because in this condition the car does not pass the State Inspection tests. The computer codes do not have enough time to become ready.
    They are replacing the IMA battery for $2760 and possibly the control module if needed (for another $1800 or so).
    My car has 96000 miles on it and I am in Texas, so my IMA battery is out of warranty. However, the new battery will have a 3 year/36000 miles warranty only.
    I wonder if the warranty period for replaced IMA batteries is like this in other places.
    Also they said that there is a "core" cost of more than $3,000 if I want to keep the old battery!
  • SeanGernerSeanGerner Member Posts: 1
    Hey all,
    Thought I would post on here a quick synopsis of my Honda story. It's similar to a lot of others issues that have posted on the forum as well. For the first 50,000 miles my car got roughly 42-45mpg on average. Then over a 2-3 week time period it drastically decreased and is only getting 32-34mpg on average.
    1. I took my car to local dealership and told there was not a problem. I thought to myself ok it's not too bad yet I will just keep an eye on it. Of course it got worse, so...
    2. Take my car back to dealership. They tell me they duplicated my issue. Called Honda tech line who told them they were working on a car with almost the same issue. Tech line told them they replaced the battery and loaded new software into the car but neither one fixed the problem. The dealership's resolution was to WAIT for a fix? Hmmm.
    3. Called honda corporate. Was told to get a "second opinion" so I took my car to the only other dealership in Tucson, AZ (Dobbs Honda) who told me they also duplicated my problem, called Honda tech line, Tech line faxed them a Questionnaire surrounding my problem that I needed to fill out so they could fax back to them and then I needed to wait.
    4. Called Honda corporate back, was asssigned a case manager who I spoke with about my IMA issues (just like everyone else is having here) and he said he would talk to the dealerships and tech line then get back to me within 1 week. He called me back and told me my car was "operating within normal circumstances" and that there was nothing wrong with it. Heat can cause it to start its safety feature which automatically turns itself off so it doesnt get damaged, etc. He also told me to read page 76 (I think that's the page) of my manual.
    5. I stayed in contact with him (Morris is his name, my case manager) over several months, continued called and expressing my dissatisfaction. Finally today he called me back again and I had a rather lengthy discussion with him. Told him I wanted either my car replaced or a $4000 credit applied to the remainder of my loan because if I wanted Civic EX gas mileage then I would have purchased a Civic EX for $4000 less than a Hybrid. He basically told me to screw myself, wouldn't give me his supervisor's name and extension, etc, etc.
    I told him I was going to no longer purchase Honda products, no longer refer people to Honda, no longer get my 2 Honda's serviced at Honda dealerships, file a NHTSA safety complaint, file a BBB complaint because I was blatantly lied to regarding Honda tech line's MYTH car that EVERYONE is told they have worked on, consistently send letters to corporate, my local dealership, and finally contact KGUN 9 News on your side here in Tucson, AZ to try and get my story aired.
    After coming across this forum I decided that I am indeed going to do each and everyone of these things, but I also might speak with a lawyer regarding a class action lawsuit because it seems that there are more of us out there than I had expected!
    Thanks for listening to my story,
    Sean
    Tucson, AZ
    "My car has 96000 miles on it and I am in Texas, so my IMA battery is out of warranty. However, the new battery will have a 3 year/36000 miles warranty only.
    I wonder if the warranty period for replaced IMA batteries is like this in other places. "
    There is a Federal law that requires a minimum of 8 years / 100K miles on the hybrid components, which includes the main traction battery. So your battery replacement should be under warranty. I am pretty sure this warranty applies to all hybrids built after 2004, but I'm not sure about before that.
    CARB states are provided with a 10 year / 150K warranty on the hybrid components.
    "2. Can I drive this car, even if the IMA totally fails and use it as a just small gas engine car but with a reduction in mpg performance. There must be reasons this won't work as it seems too easy. "
    The only real advantage to IMA over a dual mode hybrid is that it doesn't interfere with the powertrain if the battery stops functioning. So in theory you could drive it, at least for a while, without the battery. But I wouldn't recommend it - the vehicle was really meant for hybrid driving, not ICE driving, and besides 1.3L is just a DOG without the IMA...
    We have our replaced battery now, and it does work. However, we have not seen any improvement in mpg. Now, to be fair, this is Minnesota, and this one of the coldest winters in the last 15 years, but I would have expected a new hybrid to do better than my 2000 Civic LX, which dropped down to 28 mpg at the "height" of the cold snap. (On a separate topic, my LX refused to start for the first time . . . but at -25, I suppose I can cut is some slack for once!) The hybrid seems to be in the upper 20's mpg around town. The dealer was unaware of any similar complaints, but said to bring it in to be looked at.
    Anybody else seeing a significant drop off in mpg in cold weather? Note: I will excuse the Phoenix posters from offering any insights or snide comments. :)
  • ilikecakeilikecake Member Posts: 5
    My battery is toast too at 127K miles. I have the dreaded P1447 error: replace your battery pack. I was told $2700 by Honda here in upstate NY, with around $300 of that is labor. I tried to reset the condition by disconnecting the engine's battery three times but after the 50-70 system test miles the IMA and check engine light come on. Today while driving when the IMA & engine light went on, later on I noticed the IMA light is off with the check engine light remaining on. Hmm...
    And naturally my car inspection is overdue. My garage won't pass it with the error. So now I have no inspection sticker with the car totally drivable getting 45 mpg in January and I have the dumb error that I now have to address very soon.
    I am wondering about the ebay used batteries for sale, or a junk yard's... besides very limited guarantees and saving quite a bit of $$$, anythng else to consider? How heavy is the battery pack? How difficult would it be for an intermediate level mechanic (me) to change the battery pack? If one ensures the battery's big power switch is off while one works, how hard/dangerous can this be to change? Any other alternatives possible?
  • NoDakHCHNoDakHCH Member Posts: 1
    MB,
    We bought a 2009 HCH and live in Fargo. I was driving home from work at -37 (-53 windchill) driving 57mph at light throttle on level terrain (is there any other in ND). My IMA/check engine lights came on at this point. The engine temp was about 1/2 its optimum temperature (3-4 bars).
    I took it into the dealer (Corwin Honda) and found the battery had failed to communicate to the computer. The batteries would still charge and assist, but there was a point that triggered the error codes. Corwin removed the codes, drove the car for 20 minutes attempting to recode the battery failure, and gave us a questionnaire to fill out if this were to happen again so they can send documentation to Corporate Honda for testing.
    I suggested it might not be a bad idea to test vehicles in the upper midwest during winter, as they are also tested in extreme heat down in AZ or CA. So far I have been achieving between 35 and 45 mpg. This depends on how I drive (typically no faster than 70 with a light throttle and driving by the econ instead of the speedometer) and how long I have let the car run idle, as this will decrease the displayed mpg in the dash. If I am in no hurry and do this carefully, I can achieve 60 mpg on the interstate with speeds up to 65 mph, slight tail wind, no CC, and above 0 degree weather.
    Hopefully this does not occur again, but I am ready with a record book of my driving habits so I can best determine the drivability during the time of computer coding. Cold weather will drop fuel mileage no matter what simply because of the air density and heat transfer between gradients inside the cylinder heads. One idea I have is to tie in a heated battery blanket into a block heater cord, so that when the car is plugged in both the engine block and battery bank "preheat."
    Perhaps someday infrared technology will be used for window defrosters and solar power technology can keep the powertrain warm before travel. Being an engineer, I can always dream of the future, because it will never be the same come the next sunrise.
  • astephansastephans Member Posts: 1
    My HCH literally died two days ago, and then restarted. When I took it to the first honda place, they said it was the IMA. The battery needed to be replaced at a quote of 4,000 plus labor. The next place said closer to 5,000 but that it was the same problem. My warranty ran out 1,000 miles ago (987 to be exact)-- honda has the 80,000 mile warranty. Even with my extended warranty, it was not covered.
    I then took it to a ford dealership where I know the owner, and they said the same exact thing--
    The car had depreciated so much, that it was worth almost nothing at the point of trade in--- even at carmax-- because of the obvious battery problem. Apparently it had been dead for a while-- no light came on, but my gas milage went way south.
    I thought I had at least another 20,000 or so miles until this problem. I will never buy honda again! Does anyone else know of a problem like this?
  • dwash1dwash1 Member Posts: 1
    I must say I am discouraged when I read these postings. I too have a Hybrid - 2009 Civic with 6,000 miles and am also having IMA indicator light problems. My dealer tells me it is a battery problem but now Honda wants to "borrow" my car to try to duplicate the problem. Looking at all your postings it appears that they have no idea how to solve the problem and it will continue for some time. Good thing I purchased the extended warranty.
  • drlnjrhdrlnjrh Member Posts: 2
    I just ran into the exact same situation today. IMS and engine light came on yesterday for the first time ever. I took it to the Honda dealership today and they said I need a new battery. My mileage is ~81,800 so it is not covered. The service tech didn't initially offer it, but after I basically said I was a loyal customer and would otherwise never buy a Honda again he said he was going to talk to the Honda "district manager" to see if they would cover all or part of it. I'm hopeful I'll get some compensation since it is so close to warranty.
    Bottom line, I can't believe it failed so close after 80K. I saw some references in this post to certain states covering warranties on batteries for 8 years / 100K. Does anyone have any specific details on the federal or state law? I'd wanted to check it out to see what rights I may have. I live in MA. I have a 2003 Civic Hybrid.
  • lectricman52lectricman52 Member Posts: 10
    From the stories we are seeing on this and other forums, it appears that the Honda Hybrid problem is widespread. Mine started October 2007 and the local dealer did not acknowledge a problem until July 2008. At that time a technician said "This car is messed up." It has not been corrected and I recently filed a complaint with the LABBB at www.labbb.org concerning the problems I have had. This was my complaint:
    My 2006 civic hybrid has not performed properly since October 2007. It has been in the shop 8 times for the problem, but Honda is unable to fix it. I have reported problems to the local dealer's service department by email many more times. I have been told that there is no problem, that is a "characteristic of the vehicle" and that the loss of performance is "normal at this time". I have also been told that I have to "wait for American Honda to update the software in the computer" on the vehicle. Once I was told to "direct the AC vents toward the back seat of the car to cool the IMA battery" when the battery discharges in hot weather. The loss of power when the IMA fails to assist renders the car very sluggish and dangerous in city or freeway driving when normal power may be needed. A report was filed with the national highway traffic safety administration at safercar.Gov (complaint number 10241683) due to the safety issue of degraded performance. A Honda customer service customer case was opened n012008-08-2600489. The car has recently failed to assist in cold weather conditions also. Due to the number of complaints I see on the automotive forums, it appears to be a design defect and/or engineering problem.
    Honda has responded with this (spelling errors are theirs):
    After reviewing the case history on the consumers vehicle, it has been found that the consumer's vehicle has no defeft. The "problem" the customer is experiencing is a product characteristic of the vehicle, and there is no repair for a characteristic.
    Initial Response Summary
    This is a product characteristic. No repairs avaiable.
    I think all owners who have had problems should at least file a complaint with the NHTSA at www.safercar.gov and with the LA BBB. I think Sean's idea about a class action lawsuit is looking better and better.
    Is your vehicle affected by the Honda odometer issue which caused the mileage reported by the odometer to be greater than the actual mileage travelled? If so you may not actually be out of warranty.
    As the weather warms (albeit slowly here in MN), the mileage is slowly increasing with the second battery (2009 HCH). But so far we have been unable to duplicate the performance of our colleague in Fargo! A "little birdie" from Honda, who would not want to be revealed here, indicated that there are cold weather problems with the batteries (now in addition to the warm weather problems that we have heard about on this forum).
    On the one hand, I am really annoyed with Honda for not being more honest about these issues. And I'm not sure we will see the real hybrid benefit in a cold weather climate.
    On the other hand, I understand the Prius has similar problems. And I know enough Chemistry and Physics to understand that the chemical reactions are all influenced by temperature, and that all materials will be stressed when undergoing continuous temperature cycling.
    Thus, it seems that the laws of chemistry and physics will put a natural limit on the ultimate performance of all batteries. This technology is probably a long-term dead end, although it will have some short-term success. Honda is already testing a fuel cell vehicle in CA, and that looks to be the wave of the future. Fortunately, we leased our HCH, and doubt we will be keeping it!
  • reb132reb132 Member Posts: 1
    Hi, I bought a 2006 hybrid and love it but have found that the electric idle assist doesn't kick in constantly--it will work fine when the temp is over 30% but then not kick in for many days when the temperature is cold and below 30%. When I asked the service manager he said it is dependent on my driving which did not seem to make sense since it is NYC driving and the same --just seems to be the weather.
    Well, my dealer was useless in negotiating with the district manager who basically said Honda won't cover it. ...but, there is a happy ending to this story. My dealer advised that I call Honda directly to "plead my case" which I did. After calling Honda customer service they told me about a warranty extension for certain vehicles...he sited "service bulletin 86085" which extends the warranty on the battery from 80K to 84K. After checking my VIN, he said my car is eligible for this extension. I then put my dealer in touch with Honda CS and they are now covering 100% of the cost. ...definitely follow up with Honda directly on the battery issues if you're close to 80K.
  • tch95tch95 Member Posts: 7
    Talk about disappointing!!! Bought my car late November and just found out my Hybrid battery died, WTF, not even 6 thousand miles and it's D-E-A-D!!!! On a more positive note, the service center has been very good with keeping me up to date. They said they've never seen this happen before, especially on a newer model. Also, they said they ordered the battery, but don't know when it will arrive. It's been three days. Also, Honda told me they don't have a loaner car system and I am stuck paying for my own rental car in the meantime. 30 bucks a day! Should i be making a bigger deal out of this???
    We had the same problem, but at about 5000 miles.
    Your service center probably either doesn't handle many hybrids or they are just blowing you off. If you read this forum you will see that there are many people with the problem. It is a known issue with Honda and you should talk with the service manager to complain about getting the "gee, we've never seen this problem before" excuse. It reflects poorly on your dealer's sense of customer service.
    Our dealer gave us a loaner for FREE, with no questions asked (but then they saw three battery failures within a two month period). Go back and complain. If you don't get any satisfaction, complain to the attorney general in your state, or maybe the BBB. Our battery took about three weeks to replace.
  • Ogre_GEVOgre_GEV Member Posts: 263
    That's a standard 5% goodwill. Insights are covered to 150K, but they can go to 157K.
    There are companies out there that can repair your battery for less than $1,000. Search on google if you haven't bought the new battery yet.
    BTW, $2,700 is typical for the northeast, while $4,000 is typical for California.
  • timaztimaz Member Posts: 7
    I just got a 09 HCH this past weekend and was wondering if my experiences with the IMA system are normal or if I have a problem. In town and on flat highways I get about 55 MPG (according to the trip computer) which I am loving. The IMA seems to readily charge/discharge when the battery power is above 50%, but it fails to utilize the battery/IMA below about 50%. This is fine when I am in city driving, because I only need a little assistance getting going and the battery recharges to full fairly quickly, but when I drive on hills (which I often do on my commute between Phoenix and my home in the mountains of Arizona, I need the IMA for longer stretches of time. When I attempt to go up a hill, assuming my battery charge is full or near full, the IMA will assist for about the first minute (about 1 mile) and then the IMA stops assisting and the gas engine has to propel the car unassisted. The IMA just doesn't seem to want to assist if the battery power is below 50%, even if I am going up a steep hill and flooring the gas, which I would think would be enough to get the IMA to kick in. The battery is supposed to drain well below 50% before the electric motor stops assisting, right? Further, how long should a full charge last when going up a moderate incline? I read in someone else's post that their charge would only last about 2 minutes which they thought was problematic, which would lead me to believe the battery going from 100% to 50% in about a minute might be unusually fast. Since I just got the car, I don't know what is considered normal.
    I suspect part of the battery pack might be bad. I also suspect it might be because the car was sitting unused for about four months in the dealer's back lot before I bought it (which is why I got such a great deal on it). When I first test drove it, it had 9 miles and the main battery had to be jump started to get the car going, which the salesman said was because it hadn't been driven in several months. It wasn't until after I bought the car and read the owners manual, specifically the section on storing the car unused, that I read that not running the car at least once a month can cause permanent damage to the battery pack, so I suspect that might be the case. I just wanted to check with those who have had their HCH's for awhile though to confirm that my experience is in fact not normal.
    Tim in Arizona
    Actually, I doubt that your battery is bad. It does not hurt NiMH batteries to let them go dead. The problem is that worn batteries will have cells of various capacities and discharge rates, and when you let them go dead, not all the cells will. This creates an imbalance that spirals out of control.
    Your battery is brand-spanking new. The odds of an imbalance are small.
    Here's what I think is wrong. The dealer never did a battery learn procedure. Because the 12V battery was dead, it forgot the parameters. It has no idea where full and empty are. Have them reset the IMA system and relearn the battery. Make sure they do it for free.
  • sholmes717sholmes717 Member Posts: 7
    OgreGEV is probably correct. Would definately have the dealer reset the system & relearn the batteries. Most CH owners can do this buy over utilizing the IMA system and have the batteries drain down. When the system reaches 1 bar, most times the IMA system will attempt to calibrate the batteries. I believe this proceedure is explained in the owners manual actually. I know this has helped me before when my IMA system simply wasn't responding as it should be.
    I go up steep mountain highways on a regular basis, without cruise control, if my batteries have an 80% charge the IMA system will provide 2-4 minutes of assist. This variance is dependant up how much depand I place on the IMA with the position of the gas petal. If the IMA is running at 100%, I may get only 2 minutes of full blown assist before the batteries levels are down to 3 bars or so. At 3 or so bars, my IMA simply tries to limit the amount of IMA assistance but it will allow me to "burst" several times utilizing IMA at 100%. I'm able to easily drain my batteries going up long moutain hills if I'm not careful and don't plan ahead. And not planning ahead isn't an option given the Civic Hybrid has to run it's engine at 5200 RPM to simply make it up a hill on it's own (in Cruise Control mode or if the IMA batteries are drained). That is absolutely unacceptable and for the driving I do, makes the car a task to drive. On the flip side, if all you do is city computting to work the Honda can make sense....but I feel there are a good number of Civic owners who didn't fully understand the limitations of the Honda IMA system when they bought there car.
    One of my biggest complaints about the Civic Hybrid is the IMA electric motor. Because it only provides 80 or so lbs of torque, the whole Hybrid system is just to inadequate for a whole host of driving conditions. The Prius electric motor provides almost 300 lbs of torque and thus does not suffer from the same issues. The same battery power in the Prius will last longer simply because it can run it's motor at 33% power and provide the same power the Civic IMA does at 100% capacity. I guess that's what Honda gets for not developing their own technology and simply purchasing Toyota's old technology.
    After 48,000 miles, I've had enough of Honda....I'm selling my Hybrid and buying an 09 Chevy Malibu LTZ (it gets 33mpg on the highway). I can't wait to drive a car on the highway, set the cruise control, and enjoy the drive like God intented!!!!
    Totally incorrect. Honda did not purchase Toyota's old technology.
  • sa8sa8 Member Posts: 1
    Steve,
    Could you tell us where we can read up on CARB states extending hybrid component warranties to 10Y/150K (Federal law URL)?
    K
  • bbb99bbb99 Member Posts: 58
    I have a 03 HCH CVT that needs a new battery. My car has 92k on it, dealership wants $2400 to replace it, this is down from their initial offer of $3100. Does someone in CA or another CARB state want to buy my car, you'd get a great car and a brand new battery? I'm in Texas.
    You cannot buy or sell items on the forums so please don't offer things for sale, thanks.
    Thanks all for your advice. I took the car in to the dealer, they basically said everything looks fine. They said if there is a problem with the system the IMA light will come on and that everything is computer controlled so the computer knows best about when to assist and when not to. They also said there was a computer update so that might fix it. It didn't. I took your advice about trying to get the battery pack to relearn. I unplugged the 12 volt, then reattached it and drove it for about 40 minutes, which is what the owners manual says in necessary for the IMA battery pack to relearn. Also didn't seem to help. I scheduled to take it into another dealer, and they also said there was nothing wrong with it, but they found two computer updates which were available, one of which was for the IMA system. It is still having the same problem.
    Also, on some hills it seems to not assist at 6 of 8 bars of battery charge now so it seems to be getting worse. Other times it will assist until the battery it down to 4 or rarely 3 bars (like before). I have also noticed the battery will sometimes seem to drop very quickly from 6 bars down to 4, in about 10 seconds or less. I haven't actually seen it do it while I am staring at it (seeing as how I am also trying to pay attention to the road), but I look at it one moment and it is at 6 bars charged, and the IMA system is assisting, and then I look back 5-10 seconds later and it is at 4 bars.
    I described this to the dealer service guy and he said that the battery charge indicator isn't actually always reflective of the actual charge - it may just be an estimate. He also said that formerly Honda got a lot of complaints from people with HCHs that the battery would run down to one or 2 bars and then there wouldn't be enough power for emergencies so Honda reprogrammed the IMA system to not get so low. But that doesn't really make sense, unless it is reserving the 3 bars of power for when it is really needed (like when you slam on the gas), but even when I slam on the gas and run the tacaometer to about 6000 rpm, it still won't assist.
    Any other wisdom or advice? If the battery (or part of it) is bad, will the IMA light necessarily come on?
    Tim
    That is called a downward recal. They will start happening more and more frequently. On an Insight, when they start happening daily, a P1447 will usually occur. What is happening is that the car thinks it has a half charge and suddenly detects that it has bottomed out and starts the process of determining the new "empty" point. The reason this is happening is because the capacity of the battery is decreasing. Some of the cells are not taking much of a charge, so they don't have much to give. The car has to go by the weakest cell even though the rest have plenty of charge. Reconditioning all the cells and replacing the bad and marginal ones will correct the problem.
    Your car is heading for a P1433 error. When you get it, you may want to consider rebuilding the battery to save money.
  • mickeyrommickeyrom Member Posts: 936
    My God! after reading these posts,why would anyone buy a Civic Hybrid. If you check out the Prius owners comments...they all have been trouble free.To think that Honda has such a great reputation. :lemon:
    Here's a nice story follow-up to my earlier distress.
    I contacted American Honda and after a review of my case, they declined any assistance, even after saying I was considering replacing it myself, the possibility of electrocution and what the press could do with that. I thought I had laid it on very thick! No good, sigh.
    I located an IMA from a 2005 with (they claimed) 22,000 miles from a junk yard - excuse me - auto recycling center. It was $150. I repeat, $150. Its funny, when I asked who else had bought these in the past, I was surprised to learn two different inventor types bought one each Go U.S.A.! I didn't hear of someone like me to replace one. The salesperson told me, "now you know its $150?", to which, trying to contain myself, I said "that's fine, I understand."
    I took out the old one and put the new one in. I had an owner's repair manual so followed the procedure religiously. Maybe it took 3 hours going slow and safe. I went overboard with rubber gloves so that slows anyone down. I'd guess it should take a Honda mechanic 45 minutes and me shorter too to repeat.
    The battery is about 60 pounds. Later when the car was getting repaired by the dealer (not IMA related), I convinced them to take the old one, which a recycler would pick up.
    The car is fine. No software needs to be reloaded. I get approximately the same mileage I used to, although I think it was less during the winter in the Northeast. When the temperature got above 40 it seems to be pretty comparable. At 132,000, I've put 4,000 miles on the replacement. it seems to be charging fine and the capacity is about the same in the warmer weather.
    So, if you have intermediate mechanical abilities, you should consider purchasing a used IMA battery. As 2003-2005 cars are aging, the lifetime expectancy lessens on this option. But even so, $150 is real different than $2700, so if I get 48 mpg in warm (70F) and 35 in cold (20F), I am way ahead economically.
    Also, this buys me some time until Honda produces cheaper batteries (if ever) with the new Yuasa partnership, plus reuse of an old battery is just a green thing for this old earth.
  • freddierapfreddierap Member Posts: 3
    Well after 18 months of dealing with Honda service on my 07 Civic Hybrid IMA issues... and getting nowhere, I traded it for a 09 Nissan frontier truck! It's disappointing Honda has ignored us with these problems, however Honda won't have to worry about me in their shops or dealerships ever again. My new truck showed me of how poor the brakes are on the hybrid and with a V6 I actually have a vehicle that will get out of its own way again and driving easy I'm getting just over 20 mpg in town with a new truck not yet broke in... some things are much more important than gas mileage. I do wish good fortune to the rest of you in resolving your issues.
  • jorgenchrjorgenchr Member Posts: 3
    I need some help!. Am I the only one having this type of problem? I consider myself an experience Honda Civic Hybrid owner. I had an older 2003 Model and I loved it!. So I went ahead and purchased a new 2009 model. What a difference!. It drives and acts completely different from the old model I had. I am told, this is due to all the changes Honda did to the new Hybrid IMA system (Version 2 ?).
    Here are some of the issues I now have. The car has been at the Honda Service, they can not find anything wrong.
    1. The IMA acts more or less random. Sometimes it kick in for a split second then goes away when I accelerate. On the old model it stayed on as long as I applied gas.
    2. The Battery Indicator does not appear to be accurate. I have never seen it do a full charge like my old car did
    3. It often feels like driving a brick. Many times when I drive around 45 Miles per hour and want to enter a 65 miles high way, I have to accelerate to get to that new speed or I will cause an accident. The IMA seems unable to kick in!. I can see the RPM of the engine go all the way up to 6000 RPM when I try to get up to speed, the RED area is 6200 so the engine is working more than overtime. It takes up to a minute to get it up to speed and the IMA NEVER kicks in!.
    4. When I drive in mountain areas or up hills it almost rolls backward!. Well no, but again the IMA does not appear to do anything.
    BUT the IMA does work when I drive slow , but never the way it used to on my old model when it actually assisted the engine when it needed power!.
    Please help me, this is driving my crazy
    Most IMA batteries that have been sitting in junkyards will fail within their first year (usually at the 9 month mark) with P1447 or P1433 errors. This is due to the fact that they have been left sitting for 90 or more days without being charged. If this happens to you, you should not replace it again (because it will happen again) but have it rebalanced to correct the damaged caused by the extended sitting.
    BTW, $150 is very cheap. They are usually $250.
    You should take another 2009 for a test drive. If it acts differently, go back and yell at the dealer. If it acts the same, then you'll have to get used to it.
    I also have a 09 hch. I never drove an older model so I can't speak of how they compare, but I have had similar experiences, most notably that the IMA seems more or less random and reluctant to assist on steep hills, especially at higher speeds. Initially I thought something was wrong with my car, but increasingly I think its just how the IMA system is programmed. I found the following article to be helpful: http://www.cleanmpg.com/forums/showthread.php?t=13570
    It describes some of the factors which can affect how the IMA system will respond. This gave some logic to the seeming randomness of the system. I don't know if I changed or the car changed but it seems to be doing better now, after I hit about 4000 miles. I think I mostly got used to the way it drove.
    Also, there is a software update for the IMA system so you might want to check with your dealer to see if your car has been updated or not. I only bought my 09 hch less than 2 months ago and it hadn't received the update, so it is quite possible that your car also might have been manufactured before the latest software update.
  • amjad1amjad1 Member Posts: 1
    i just bought my 2003 hch car 1 week ago ,the ima come on all of the time ,& the MPG is too low around 23mpg ...plz help me what i have to do
    You first need to find out if it is the battery or some other component of the IMA system. Get your codes read, either by a mechanic or at autozone. Post them here and the state you're in and the mileage on the car.
    The warranty is 8 years/80,000 miles on the battery.
    Does anyone know what that software update is called? My dealer told me Honda never had any updated available for my car
  • hunter44102hunter44102 Member Posts: 2
    Software update is called a PCM update (powertrain control module update). I just had it done on my 2006. Fixed a problem I had with acceleration.
    What i meant to ask about is, what is this specific update that was made available for the 2009 Civic's? My dealer tells me that car does not have any updates available.
    My receipt from the dealership says "updated PGM-FI WITH LATES SOFTWARE 37805-RMX-A130, ALSO UPDATED IMA BATTERY CONTROL UNIT WITH 1K101-RMX-A110 OP#125517A"
    Not sure what everything means, but hopeful that can help.
    I had the work done 4/14 and I have an 09 HCH delivered to the dealer in 11/08. I don't know if possibly my 09 was manufacturer earlier than yours. I would guess the cars being manufactured after the updates were released would already come with the latest software, so perhaps your car already had the latest updates when it was delivered.
  • bp_madmanbp_madman Member Posts: 1
    You are not alone in regards to this matter. I thought I had purchased a great car. I've had my 2009 Honda Civic Hybrid 7 months now. The first 5 months I experienced no problems with it. Now, there is a notable difference in how it accelerates…or should I say lack of acceleration, to the point of being dangerous! To top things off, the dealership from where I purchased my Hybrid, GREG MAY HONDA, in Waco, TX, refuses to acknowledge a problem actually exists. I would NOT recommend this vehicle to anyone.
  • ulrike1ulrike1 Member Posts: 1
    I have had my 2009 Civid Hybrid for 6 months and am experiencing the exact same problems with the IMA that have been described here. This includes the frustration with the dealer telling me that this is a known problem at Honda, but no plans to really do anything about it. And being told that the problems are because of the heat here in Texas. I also would NOT recommend this car to anyone. I am trying to figure out a way to get rid of mine without too much financial pain.
    I recommend registering your frustration with American Honda. I've found they listen, investigate, and sometimes react favorably. If something good comes out of it, be sure to come back and let others know (and to avoid this forum just being complaints without the other half of the story).
  • joek11joek11 Member Posts: 2
    I am having the same problem in my 06 Civic hybrid. I took the car to the dealer and they couldnt find anything wrong with it (using computer error code read outs). So I told them to leave it out in the 103F heat all after and then drive it for 5 minutes around 3pm. Sure enough the problem replicated itself while the tech was in the car with the computer hooked up for error reading. Much to my suprise Honda took the problem very seriously. They took a computer snapshot and sent it into Honda regional office for further diagnosis.
    HOWEVER after about 2 days of waiting Honda came back and basically said, "Sorry this is a known issue. Nothing we can do. We will call you back when we have a fix for this problem." The official documentation I received from Honda said, "heat issue".
  • kamckamc Member Posts: 2
    I am having the same problem. I took the advice to call American Honda. After a detail explanation of the problem, the operator refused to help me. She was trying to be nice since I was very polite to her. The final answer was - too bad, you got a Honda, and I was not going to help you. I am not sure why Honda is not listening. I am sorry that I have not find this site before I got my lemon. Now, I don't know what to do? Please help me. I can't afford to sell the car, and buy another one. Last Honda for me. I am going to Saturn.
