Other Engines for 93 Trooper?
What other engines, maybe from other vehicles will swap with an existing SOHC v6? I heard that some other GM engines work.
However, the automatic transmission is rated for 250 ft.lbs. torque, at least I think I read that once. So it could be possible to find too much engine for this transmission in the high torque Trooper application. Even if a higher hp motor is available designed to push a lighter car, that extra hp might translate into too much torque in the Trooper application.
Also, you need an engine that has power in the right RPM ranges to match up with the gear ratios this transmission has for the Trooper specific version.
Somewhere there is available a supercharger for the Trooper 3.5L engine, less than $3000 I think.
1. I have a 1993 Trooper with a body in excellent condition, a nice interior, and recently rebuilt tranny.
2. I don't have to rely on it for every day use.
3. I can afford to spend some money to make it a real performer. Not too much, but unique.
4. I really miss driving it, especially fishing at the beach.
So I'd be open to any suggestions for replacing that bad motor, and someone help me figure out how to recoup my losses from the mechanic who charged me $2500 to put in a motor that would last only 8000 miles.
Thanks for the reply. So, who is Jerry Lemond? Another "easy" swap I was considering is to use the Isuzu 3.5 and do a hiperformance rebuild on it.
When you rebuilt your engine, did you do a stock rebuild or opt for any hipo options? And if you did what did you do and who were the manufacturers of the items you changed or n modified?
Thanks, George
