Honda Accord Transmission Questions
in Honda
Honda Accord Transmission in Stop & Go Traffic
My old car was a 1992 Lexus LS400 and an excellent car. The transmission was very smooth, and you could barely feel the transmission shift (it was a four speed).
I recently purchased a new 2007 Honda Accord LX V6. The transmission shift is a bit harsher than I’m used to, but still reasonable compared to cars in this price range in normal traffic. In typical traffic, the transmission is perfectly fine.
However, in Los Angeles rush hour freeway traffic, the transmission is a bit jerky at times and the shifts are much more noticeable. In typical LA rush hour traffic, you could be moving along at 5 mph, speed up a little bit to 12-15 mph, and then come to an abrupt stop. Repeat this for the next 30 miles.
When moving at 5 mph, I assume the transmission is in first gear. I add a little gas with a light foot to move up to 12 mph. During this, the transmission shifts into second gear, and the transmission “jerk” is very heavy and noticeable. I’m now moving at 12 mph or so and then come to a complete stop because of traffic. The transmission also very noticeable shifts from 2 to 1 (like the slow shift from 1 to 2, the car jerks).
I assume this is normal behavior because this type of jerking at slow speeds also happens on my 2004 Toyota Sequoia, which is a V8 with 4 speed transmission.
I assume this type of constant transmission jerking for 3 hours a day (the amount of time I spend in rush hour traffic a day) must be very bad for the transmission. I try using D3, but obviously that makes no difference as that only keeps the transmission to the first three gears (and the issue is at slow speeds with gears 1 and 2).
My friend suggested that during rush hour, I shift to 1 and drive the car in that gear. That way, the transmission stays in 1 and avoids the constant upshifting/downshifting. Is this a good idea? Won’t this lead to a lot of high-revving by the engine? Will this damage or cause extra wear on the engine or transmission?
Thanks!!
Thanks!!
Any opinions regarding driving the vehicle in first gear in heavy stop and go traffic? Thanks!!!
To leave the transmission in 1st gear you would have to be going pretty slow. I'd say 10mph or less. If you are turning 3k rpm at 15-20mph, your mileage will suck IMO. :P
4000 miles - mostly highway. Noticed the car downshifts (sporadically, but often) a bit soon, quite abruptly in stop and go traffic, or simply slowing to normal stop. Not sure if it's from 3-2 or 2-1 but whoa - jerks and can be quite unsettling. may take it to service to have a lookif it continues..... :confuse:
My advice would be to sell or trade the car while its still worth something. Your rebuilt tranny will fail again in another 50-80k miles.
Honda had a class action suit for the widespread V6 transmission problems. See this link: link title
We owned 2 Honda V6 cars in past 5 years with transmission failures under 100k miles.
Any help would be very much appreciated.
A rebuilt transmission is approx. $3-4k installed by Honda. You could shop for prices & possibly get it done for $2-3k.
KBB says your car is worth $7-8k. However, with the real high miles a dealer probably won't give you more than $3-4k for the car.
I just traded a pristine '00 Odyssey EX with 150k for $3400. KBB said it was worth $5800 on a trade. Tried selling it in the local paper for 2 months. Not even a phone call.
You probably don't have much of a choice other than to fix it. What else would you do with it? After the repair, I would have it detailed & try selling it privately.
The V6 Accords had tranny problems and had warranties extended on them because of it. The 4-cyl Accords never had such problems.
I've got a '93 with nearly 200K and on the original tranny. It shifts a little hard occasionally, but nothing out of the ordinary. In fact, it shifts smoother than a 2001 Corolla that I used to drive.
Have had to use my key in the shift lock release 2 times today. Strange thing is that just last week we had the transmission flushed. Was running great until today. I know very little about Hondas or most cars - so an elementary explanation would be greatly appreciated!
The owner's manual said that if I've had to use the Release button - it probably means that something is needing a "Honda Dealer's" attention.
Thanks for anyone's help!!
Elroy will chime in soon (he's good about having answers
Best of luck,
TheGrad
1996 Accord LX, 178,000 mi
2006 Accord EX, 29,700 mi
Sure, if you can find the time, get estimates from a few places. The dealership knows Honda cars better, but they are usually more expensive too, so that's entirely up to you.
Keep us posted on your situation!
Best regards,
TheGrad
You got that right!!
Elroy, as the graduate noted, your input around here is very helpful. Thanks very much!!
This link only covers up to the 95 model Accord, but it may help you find yours. Good luck
http://techauto.awardspace.com/vss.html
P, D changed over the sensors records and seals
My tranny shifts rough, I took it to a shop and they said the tranny came up with no problem codes. I had the fluid changed, no changes. My speedometer wasn't working so I changed the VSS on the trans and the speedometer works but still rough shifting. My D4 light does not blink or stay on. My next step is to get a computer reading on the car and see if any other codes come up.
My question is, what other factors could come into play when the tranny shifts rough but no codes show up ? :confuse:
http://techauto.awardspace.com/transmission.html
PS: You may want to save this link, for future reference (many troubleshooting tips for 4th gen Accords) I know your Accord is a 5th gen, but many parts are the same.
This has nothing to do with a transmission problem.
It's not that simple, unfortunately. It's not the cable going to the Throttle body, and it's pretty complicated. You would have to have a service manual for your car, and my service manual was sold with the car. Sorry
