Chevy Tahoe dome lights stay on
Stopped at a stopsign the other night. When I tapped the brake the dome/interior lights came on! I got them to go back off by depressing the "dome override" button a couple of times but now they stay on all the time. I have to keep the override button pressed in.
Anybody got a clue??
Here's one suggestion:
mitzij, "Chevy Tahoe" #4486, 12 Apr 2004 9:56 am
If you click on the Chevrolet Suburban & Tahoe link above, you can do a search just on the Tahoe for dome light and see the other posts. The search box is at the top right of that page. Maybe one of the older posts will give you an idea of what to test.
The vehicle has a body control module, which is a separate computer the manages many of the lights, door locks, power to radios, etc. A bad switch could be sending a door open condition to the computer, which is then not allowing a lot of other things to happen as 'normal' conditions.
Go check the switch.
olearymag
SUVs and Smart Shopper
Can you elaborate on the door switch comment.. Is this inside the door panel or a sensor around the perimeter that can be replaced? Same problem as others with the Tahoe/Burb but on "Right Rear Door Ajar"... Thanks!
- plunger type switch. If you open the door and look around the complete edge of the opening, if you have a plunger type switch it will have a top that is sticking out. When the door is shut, it makes physical contact with the top and is depressed in. Sometimes the switch is up on the front hinge edge, other times you may find them on the back edge. Sometimes you'll find them as a metal topped plunger, other times a rubber waterproof plunger.
- door latch opener switch. If you don't have one of the above, then most likely it is inside the door itself on the latching mechanism. The latching mechanism is on the back edge of the door, and typically engages a metal post on the cars pillar. You'll have to take the inside door panel off to get to it.
Did a door latch assy. fixed your problem? I having same problem with Rt rear door ajar and I have replaced with a new latch assy. After a long wiring diagnostic I've noticed a body control module under a steering column there is a wire harness connect to BCM, when you wiggle test each wire harness it will go away then it comes back on again.
