Volkswagen Passat GPS
I have problem with my VW Passat GPS. I am from Lithuania, and I can't see any maps from this country when I drive. Can You help me, what DVD I have to buy, that suits on VW GPS?
Coming out for 2009 MY. Has touch screen and a hard drive. Stores music and navigation on it. Plays DVD's while in park. Bluetooth is also supported. Works with HD and sirius radio. Stay tuned for more info.
3C0 036 684
Now avaliable at the VW dealer for a cool 3499. There is going to be an RCD-510 which has a 6 cd changer, touch screen, phone integration, and sd card. Just no nav on that unit. The RNS-510 is the one to get.
http://www.lutschi.biz/album/RNS510/
Gallery of this new navigation system. That is the Euro version but the USA is identical. Bluetooth from a Skoda works with this thing. Touch screen dialing. For those with Cingular and T-Mobile a premium bluetooth is also avaliable. However a USA bluetooth module with BT audio is going to come out as well. That unit will have full integration with RCD and RNS-510 units. The bluetooth unit will have to be programmed with the VAG com tool. Also it will have to be plugged in to the Insturment panel in order to have full integration. 2009 is when factory installed BT might be avaliable but can be retrofitted.
Sirius is built right in. So is HD radio. Will require an antenna for Sirius. Also some antenna adaptors will also be needed. Works with Dynaudio but will have to be programmed at the dealer or use VCDS aka VAG-COM. VAG-COM v7.11 beta will code it and so will 8.03 beta. The DSP sound system might have to be coded as well.
Hope this helps.
I dont understand the price of 3,499.00 I dont know who would be willing to pay this amount of money.
My question is, if I purchase a passat with nav see option below
MSRP Dealer price
PIP DVD Navigation w/iPod Adapter info $1,800 $1,589
are they the same unit? if yes why so much money.
I recently bought a passat without Nav thinking I would add it myself. if you are correct on the pricing, then I made a mistake in not getting the nav.
The RNS-510 must be a different unit then the option given.
any info would be greatly appreciated.
The MDI is an addon you can install to the RNS-510. Replaces the aux and iPod/Cd Changer. Requires a special MDI iPod cable but gives you full integration.
I hope the price go down in a near future.
Jus curious, Does the kit comes with information on how to install it? What tools will I need, etc.
are there any resources that would help me install it myself?
thanks in advance,
J.
vwnavi.com is a great resource for this system.
Thanks much for the info.
I will wait until it comes down to $1,200.00
Although it seems like a great system, I dont want to pay 2K for a GPS
"The MDI is an addon you can install to the RNS-510. Replaces the aux and iPod/Cd Changer. Requires a special MDI iPod cable but gives you full integration"
1)Are you saying the iPod adapter that comes factory installed with the RNS-510 is terrible? Why is that?
2)By 'full integration' do you mean the track/song titles are displayed on the RNS-510 nav screen?
1. I was referring to the current iPod adaptor that can work with the RNS-510. The MDI is the new iPod capable device. The current one is just a CD changer since it uses CD changer derived hardware to play iPod.
2. Yes it does show track and song info. It does require a cable that is currently on back order. 000 051 446 C is the part number for it. The MDI also relies on the CAN-bus to display song titles. Only the RNS-510 works with it at least in USA. The RCD-510 is very similar but with no nav and the hard drive. The RCD-510 has the hardware to work with the RNS-510.
I have a 2008 Passat with the DVD nav unit=MFD2 I guess?
If I wanted to upgrade to the RNS510, I would have to pay $3500 at the dealer?
Hope this helps.
It will require VCDS programming if you have dynaudio. If your stereo has an amp then programming is also needed.
The MDI iPod cable is now in stock. 000 051 446 C is the part on that and it's slowly getting into dealers. Dealer can probably order it. It's just a cable but you cant use your own iPod cable due to the MDI's design. It's pricey but has full integration on compatible iPod's. VW isn't advertising this as an iPod adapter but it does play iPod's. It doesn't work on the non nav radios since they didn't upgrade those yet. The MDI and RNS-510 have full iPod integration with that cable. It uses it's own interpretation of the iPod interface. It works like an iPod not a cd changer.
Hope this helps.
GPS do the same thing?
I don't understand the benefit of having a 2,000.00 GPS in the car radio. The Tom Tom can be taken out of one car and put in another like when you rent one.
The Tom Tom allows you to download other countries maps on their Web Site very
cool when I drove Ireland.
If anyone wants to share an opinion I would welcome it.
