Lincoln Town Car Noises/Clunks/Squeaks
I have a 1999 TC and I have been hearing a ticking noise that sounds exactly like the turn signal, only the signal does not blink. It usually happens when I hit bumps or when I am going uphill, but sometimes it is simply random. It sounds like its coming from behind the gauges. Also, it usually only ticks once or twice at a time. Anyone have any idea what this might be?
I am having the same exact problem
Did you find out what it was ???
The noise sounds like you are running on the bumps that are on the side of road(rumble strips)It happens at 20MPH or higher. It lasts a few seconds and at different times. It might make the noise once every few miles, but certain time.
Any ideas?
No more rattle over the bumps.
Any ideas out there?
On our 94 I discovered where two metal plates behind the spare were contacting each other. I wedged them apart and inserted a sponge. The plates run from left to right.
Sometimes it helps to have somebody drive over bumps while you're in the trunk with a flashlight to more accurately see to hear.
When you find the source you will feel wonderfully good.
Since then when riding along; I have this sound that mimics the sound of the engine.
along with the hearing the engine( if that makes any since). I returned it to the shop and the
machanic can't find the problem. Any suggestions?
