Chrysler 300M Life Expectancy
I have a 2001, 300M with 128,000 miles. Can anyone tell me what the top mileage I can expect from a well maintained engine?
Thanks, Matt
Thanks, Matt
Mine has almost 163,000 miles on it and it is still going strong and has had very few problems (power window issue, transmission sensor, ATC failed). It has been driven fairly hard but maintained well (2 total transmission flushes, spark plug replacement, regular oil changes, etc..).
I have owned numerous other makes/models and never thought I would keep a car with as many miles as mine has, but again, the car is so well built that I am not even considering buying something else.
In conclusion, I would reccomend this car to anyone. Just be smart when purchasing a used car; spend the $50-$75 and have a mechanic you trust look over the vehicle and fun a detailed car-fax.
My car now has 224,500 miles on it and drives great. I use 1/8th of a quart of oil in 1,000 miles. I change oil every 4,000 miles now. I changed every 3,000 miles before it hit 200,000 miles. I had a tune up each 100,000 miles, which is basically just the installation of new spark plugs. I follow the maintenance schedule in the owner's manual very strictly. When the transmission fluid gets a bit dark (after 50M-60M miles), I get all of the old fluid pumped out before putting in new fluid. Apparently, if all you do is drain the fluid, there will remain a few quarts in the transmission which, unless you pump it out, will contaminate the new fluid.
I went on an 800 mile trip when I kept my speed at exactly 75 mph and made very few stops. I averaged 27.1 miles per gallon. When I pay no attention to saving gas and just drive like I want, I average about 24 m.p.g. On long trips I drive between 65 and 95 and still get about 24 m.p.g. The torque from 0 - 60 is so so. But the torque between 65 - 85 is great.
I hope all of this helps. Enjoy your Chrysler. Your e-mail address did not work.
Yours truly, K. Rogers, Memphis, TN, USA
When I bought this car, I did not get good reviewed from so many of my friends for being the car would run into so many problems, but I have seen those folks change their cars, but still I am running solid.
I will hold on to this baby till its last breath, until I will go for a new brand maybe, wonder that will last like her.
My 2001 300M has 190K on it, and once again I was deciding whether to put some $ into it or move to the next big thing.
Basically, it needs tires and the hvac fan doesn't work. Poking about on the intertubes, I saw things about control modules and resetting by pulling fuses. The fuse trick didn't work, so I went to the dealer, $95 diag fee to tell me it needs $500 fan motor, ordered from LA.
However, while poking about on the dealer website, I saw they had a 2008 300C Hemi, so I decided to buy that before I knew about the $500 anyways.
So, any ideas about what to do with the 300M? Service guy offered me $2K, I said I could do better donating it (now having second thoughts, of course). It's a nice car, only serious complaint I've had is 4 trannys (1st right after warranty expired, sigh). So it has only 22K on an OEM upgraded tranny. Since I drive so much, I tend to take much better than average care of my cars. I'm thinking put it in autotrader for $2800, with note about fan and tires. Am I dreaming? I'm near San Diego. I'm no salesman.
Gold/tan, sunroof, premium sound, chrome wheels, couple very minor dings, driver seatback worn/cracked. Passed smog with flying colors last year. Most miles 80MPH on freeway.
The 300M is just a beauty inside out, well built, and I would like to keep it for as long as I can until I get into endless engine problems (hope not).
Thanks in advance.
Getting many unsolicited compliments on 300C, seeing lots of similar ones around. People think the remote start is so cool, I'm starting to be startled by their reaction because I've gotten used to it. 300M had better ride/handling, I miss a few things like better feel on the garage door buttons, instant fuel economy readout, predictable buttons on the radio, auto adjust based on which key remote used. Some things I perhaps simply haven't figured out yet, not sure if they are things wrong.
This is an update to my old post back from Dec 08. Car currently has 195k miles. Did a first tranny OEM replacement at 130k miles with 3 yrs 36k mile warranty. The one major issue I had after that was last year while my steering column got jammed while taking a turn from a set of lights, thank god it was not an highway. Costed me around 1k to fix it and then some minor tail light issues and other things during state inspection. Last month after almost 3 yrs of tranny replacement, while driving on my highway I lost transmission power while driving even though the engine was on. I was like man here it is the car is dead. I have crossed the 10 yr ownership of my car last Dec 2010 and with 195k miles, was not sure what should I do. The dealer said its tranny and 4k to get an OEM. This time chrysler offered 3 yrs 100k mile warranty. I ranged up couple of more dealers and one gave me an offer to fix it at 3k without looking at the car, even though the car was at a different dealer. Still we had a single car for a 2 person working household, rented a car for a week before to decided should I go for a new car or fix it. Well KBB value was 2k, but the car was not even in drivable condition. Not sure even how the donation worked on such cars. Even if I were to look for a second hand car of same 300m it was going around 5k.
So finally after much deliberation I decided to fix my tranny one more time (2nd time), considering I knew my car well and the same dealer match the price of tranny fix and he said the car is in good shape otherwise. There was a oil leak in the transmission line he mentioned that needs to be changed/fix, which I knew as I have seen oil drip while I parked the car. The main thing that convinced me to fix the tranny second time was 100k mile warranty and the dealer said he will give 1 yr warranty on his work. As my car tires were new which I bought from Costco again for 400$ all four with 90k mile warranty (Michellin), in all angle it made more sense for me to fix my baby again. As he started the work he said it needs new radiator, man I am now into this and can't back out. The total expense after everything costed me 4.5k. Whew, thats a big amount. Its been a month now the car is back on road put 500 miles. Hope I can pull the car without major issues for another 1 year and cross the 200k mile marker which was my initial goal. The only issue I have now is the silencer is making noise and not that loud, the dealer said its because the car is old and the line is rusted and while removing the transmission it gave up and since there is a small gap thats the reason for the noise, the permanent fix would cost me 1k, I said no and he just did a temp fix to subdue the noise, but said the noise will slowly increase as I will drive more. Let see how that goes. Hope I can get some ROI on my 4.5k invested for now.
Chrysler 300M is really a good car and very sporty looking compared to 300C. This is one of the better roomier car, not sure if I can find any other car with such room. I am ready for new car I guess in next 6 months to 1 yr. Since I had been die hard fan of Chrysler for 10 yrs wanted to try a different manufacturer, now I am very much hooked and sold to Volvo their XC models.
Thanks for reading guys! ">link title
One issue, however is a little rust on the inside of the rear doors. I had it repaired a few years ago but it has returned.
Current owners: Be aware that a not to high speed crunch into someones bumper (300M hood, right fender, right headlight, some front bumper damage) results in > $6k damage effectively totalling it. Unfortunately the value of these cars has dropped a lot, perhaps due to 8 yrs of age but insurance effectively added $1500 more with low mileage and options so go figure. I always had concerns on doing any work on this engine with such a compressed engine compartment but this model does seem prone to being easy to wreck, although all I really care about it my wife walked away, airbags did not even go off.
Good luck all of you who are still driving this as I will not even consider a new 300: don't like the style of even the sorta smoothed out 2012 300's and driving a RWD car in MN snow is stupid, too bad Chrysler did not stay w/FWD as the $2k option for AWD cuts the gas mileage too much. I want to get >30mpg highway mileage so will probably look at a mid size something, possibly a 200 but more likely a Fusion, Malibu/Lacrosse or possibly Passat, Camry or Accord.
Again, take care of all those 300Ms out there, love that car!
First: Dec 08, Second: Mar 011, Now March 13.
Currently I have around 225k miles on this 2000 300M chrysler, from my last tranny fix, I pulled off 2 yrs. During the course of two years, I have probably around 2k exp on regular maintenance, one tire change and OEM oil can change and brakes probably.
I always oscillate to buy a new car whenever my emissions sticker would fail and then I end-up fixing it. Recently the car breaks were gone and the ride started to wobble and the service tech said tie rods were gone and they estimated a 2k exp to fix it and he said, its not even worth it considering the miles on the car.
I decided to come back and update this post, as I just now bought myself a brand new car 2013 Lexus ES350, the only car in my analysis could match in all expectations to my 2000 300M chrysler. The dealer said from the trade-in value he will offer the fair market value of KBB just a approximation, but he said, they always go by the last auction sale price. So my car was valued around $1500 maybe. Still I haven't traded it in, as the new car would be the second car in the house hold. But I will eventually will be either trading it in or donating this car I guess.
All I have is till Sep 2013, my emissions sticker, after that I can't even drive the car, unless I fix it... so probably getting rid of this one before then for sure.
Well I definitely got the ROI for the money I spent on the car for 2 yrs, 4.5k tranny and probably 2.5k over 2 yrs maintenance..... I pulled 13 yrs and 225k miles not bad for a 300m Chrysler.
I will post a one last final post after I either trade-in or donate my car.
Thanks guys, now I am a new Lexus 2013 ES350 owner.
WHY DO I FEEL LIKE I'M DRIVING A TIME BOMB?
DOES ANYONE KNOW HOW LONG BEFORE THE BELT WILL BREAK AN RUN MY VALVES INTO THE TOP OF MY PISTONS?????
THE COST TO CHANGE OUT THE BELT WATER PUMP AN IDLERS COSTS AROUND $1000 BUT
I AM AFRAID TO DRIVE IT WITHOUT GETTING IT DOME.
CAN SOMEONE TELL ME HOW MANY MILES IT SHOULD RUN BEFORE BELT BREAKS?
THANKS A BUNCH, HANK
