Hyundai Sonata Tires and Wheels
My 2006 Sonata LX has Michelin 225/50x17 tires that give it a noisey and hard ride. 2007s have Michelin 215/55x17 tires. Would changing to that size or another brand improve these?
If available, a 225-55/17, and if it fits, would give a slightly softer ride.
When that time comes, I will likely buy replacement size 235-50/17. Sidewall height should be same as present 215-55/17 with about 1" wider foot print for a similar ride. The 225-50/17 has a shorter sidewall height resulting in a slightly harsher ride. Those who choose 45 or 40 aspect ratio tires must love punishing buck horse rides.
http://www.discounttire.com/dtcs/infoTireMath.dos
The referenced tire is V speed rated(remember the speedster that was clocked at 147mph in AZ?)and is good for the max speed of the car. The Sonata V6 has a measured top speed of 137mph by C & D. Tires of lower speed rating may overheat at higher than rated speeds and rupture.
Yes most folks don't do those speeds but there is always the very few that like some excitement. Many domestic cars are speed limited to about 110mph to use cheaper, lower speed rated tires. I am glad that my 2007 Sonata Limited does not have that limitation.
37K miles and more is great for V speed rated tires. Many/all higher speed rated (eg Z) last maybe only 15K due to their softer rubber that provides better traction.
http://www.maxxistires.com/AutomobileLight-Truck/High-Performance/MA-Z4S-Victra.- aspx
http://www.falkentire.com/Tires/ZE-912-2
did you ever find a suitable snow tire? am i going to have to shell out $150 a tire or is there something decent for less? I was trying to make a left at a light last night and i was so stuck it took 3 light cycles for me to move my car. Those hancooks suck in the snow.
It seems the sonata's rims on the limited love to gather snow and hang on to it. It really sticks well to the wheel-wells too which is bad for business.
Thanks, and good luck this winter!
Sorry if this is a repeat thread. I bought a brand new 2010 Sonata in April 2010. So far I only have 2500 miles on it. The problems I am having are:
1. When I apply the brakes, there is some vibrating sounds coming... Has anybody had similar issues...
2. The passenger side front tire does not hold air more than 25-26 psi.. If I raise it to 34 or even 32 psi, it drops down to 26 psi within a week and then stops leaking... Has anybody experienced this strange issue...
I am taking the car to the dealer on Friday April 15 2011...
Can somebody let me know if this is covered under warranty...
The tires have a limited warranty, but brakes etc. are covered if defective. However, if the problem is due to "misuse" including an accident of some kind, it would not be covered.
Best to take it in to the dealer before its 1-year anniversary, as there is a one-year/12k mile adjustment period where just about everything is covered.
Yes I will be taking the car just 3 days before 1 year anniv. (not a good sign if you ask me).... So any particular reason why I should take it before 1 year anniv....
2pac
Be sure the problem is documented on the service order, so if it is not fixed the first time it can still be fixed under the 1-year adjustment period (if that applies here).
Good luck!
