Toyota Sienna Service Questions
we had our 2001 Sienna in for a regular service. The shop owner, who has been incredibly honest in the past, called and asked if we had the timing belt changed at 90,000 miles (necessary since the car now has 120,000). It wasn't in their records. We didn't remember so we told them to go ahead and change it. They called back the next morning and said that it had already been changed, so they adjusted it. They charged us $125 to adjust it... Now, does the timing belt need adjusting or does it auto-adjust? I think he is charging us for the wild goose chase he started. Thoughts or knowledge would be appreciated.
That covers their labor cost, basically.
Oil & Filter: manual says 5K mi or 6 months -- seems too long/infrequent?
Transmission Fluid: manual doesn't really say, but maybe every year or 12K mi?
Timing belt or chain: Do '08 Sienna's have a timing belt or chain? If timing chain, when should I make sure to inspect it? 100K?
Thanks for your help in advance!
Trans fluid - I'm not sure. I doubt it needs service so frequently, though.
Timing chain, definitely. Up to 06 they had belts, 07 and later have chains, thankfully. I think they call for an inspection at some very high mileage number, but I don't recall. That should be in the service manual, though.
It's a very good powertrain. Car & Driver did a minivan comparo and said the Sienna had the best powertrain, hands down, no contest.
Ateixeira, have you changed out or cleaned your cabin air filter yet? The manual says to clean with forced air every so often and replace if too dirty. Looks like you have to remove the glove box to get to the cabin air filter. Not sure how much the dealer will charge to remove and clean or replace. I did it myself on my CRV as they wanted about 100 bucks to replace. The part was 15.00 and it took about 15 minutes.
Thanks for your input!
replace water pump, timing belt, drive belts
replace rear shocks
transmission fluid flush
positive battery terminal: replacement and service
All for $1483. We called another garage and they would do this for $863 but not Toyota parts.
Is any of this necessary? and is it worth it for an 11-year old vehicle? (with a bluebook price of ca. $3000 min.) or should we start looking for a new vehicle?
Yes, Toyota didn't at first realize how really useless a F/awd system that in reality was a simple ONE-WHEEL could be until there was so much owner outcry that they had to provide the TC disable capability as backup.
$863 is not that much - it would not cover 3 car payments.
If that extends the life of your van more than 3 months, you got your money's worth, and it seems very likely it will.
You're well past warranty so no need to use OE parts.
Do you know there jave website to buy toyota online OEM part?
such as disk apd, drive belt, spark wire set, etc?
