Ford Edge Gas Tank Problems
My 2007 Edge will not fill the last two or three gallons without going in at small spurts at a time. Dealer referred to Ford Motor Co. as normal for this vehicle. My daughter in law has same vehicle and does not have the same problem. Does anyone else have the same problem.
Try pumping at less than full blast.
Mark.
Common blockage issues are with the canister close valve and the canister filter. But you could also have a defective fuel cut valve in the tank or a blocked canister. You could also have a problem with a restricted hose or pipe either not allowing proper venting or not allowing the fuel to enter the tank properly."
Can anyone tell me what I should expect for cost to have it replaced??
Thx!
