Mercury Mariner Tires and Wheels
There is a lot! of tire road noise from my 2005 Mariner. The faster you go, the louder it gets. Has anyone experiened the same thing, if so I would like to know what did you do about it, did you change tire brands, did it help, etc. Any help would be appreciated.
Thanks, Bill
Thanks, Bill
They did not do it right. A proper "tweek" would not have resulted in a pull. (OK, there is a possibility that the tires have been worn so they pull. Swap the front tires and if the pull changes, you will have to replace the tires to get rid of the pull.)
Mariners and Excapes have too much camber. If there is even a little bit of toe, you'll get one side, irregular wear.
I'd recommend you get another alignment at another shop and have them dial out as much camber as they can. Make sure they get the cambers the same on both sides. Just be aware that fixing the alignment doesn't fix the wear on the tires (Kinda hard to put rubber back on!)
