Just put a fresh 2.6 engine in a '91 trooper. It runs great but O2 and Check Engine lights on. Tried resetting but they come back. All I can think of is I hooked something up wrong but no clue where that might be. As I said it runs great so don't think it's a vacuum line or anything like that. Anyone have some guidance for me? Thanks.
All this assumes that your transfer case is working and that it really is going into 4 WD. I think in 96 Isuzu went to shift on the fly, so yours is basically as described, stop, put it in 4WD, and drive. HTH One guys opinion.
1- The Airbag Light is permanently on
2- The horn does not work.
Being that they both are in and around the steering column, which was disconnected from the steering box gear knuckle during the r/r, I assume this is not a coincidence. What did I miss? Is there a switch or a cable that has come loose somewhere? I disconnected the battery to see if it would reset but it did not.
Hi Everyone, Can someone post the icons or pictures of the Dashboard warnings and its meaning here? I am new here and I got an Isuxu Trooper 2002 model with engine number PABUR JX4 I think.
Any help would really be appreciated
