Toyota Sienna Towing/Trailer Hitch Questions
I often carry a 1980 Honda 110 Trail motorcycle on the back of my 2002 Ford Expedition. I can't even tell the bike is back there. I am thinking of replacing the Expedition with a minivan in search of better mileage. Does anyone have any experience using a hitch carrier like this? I don't know if the Sienna can hack hauling an [approx.] 190-200# bike on a hitch. It will have to be a Class III hitch to fit my equipment. Any of you use a hitch on your Sienna like this?
http://www.siennaclub.org/forum/lofiversion/index.php?t518-50.html
Its a big bag of wires and parts with no instructions, and it looks like I have to pull off panels and hide wires all the way from the dash to the left rear interior panel
Anybody attempt this on their own or should I let a pro do it, dealer or otherwise?
I opted to not buy the ~$150 OEM wiring harness and decided to do it myself. I got a HOPPY #48845 Trailer Wiring Converter (cost ~$20) and watched the video on how to get to the brake and turn signal wiring on www.etrailer.com. With that information, it was easy to wire the Sienna. FYI - on the 2007, the green with yellow stripe is right turn, green with black stripe is left turn, green with white stripe is brake light, and solid green is running/tail lights. Hope this helps someone out, as I couldn't find this info on the 'net before I installed it myself.
Cheers
jb
The rear end is a bit lower than the Windstar so we will probably opt to purchase a Wight Distributing Hitch as well to pull the rear end up.
Anybody have any experience towing campers with the Sienna?
Appreciate any thoughts and help!!
For 2008, they made this an option, but most vans in my region still got it.
I know 07s had them standard, though.
Pulled a 1200 pound tent trailer to PEI and back last month. It was so easy I had to look back at times to make sure the trailer was still there. Great towing vehicle and I still got 18.5mpg on the trip while towing the trailer.
I had a 1998 Forester that averaged 25.1mpg over its lifetime, and I got about 18mpg on one tank while towing the whole time.
I'm sure the big V6 simply handles the load better.
Now if it will just cool down a little, it will camping around here a little more bearable.
I don't see why it could not be added, though, isn't is basically an oil cooler?
I noticed when building a Sienna on the Toyota web site that it states the tow package is not allowed. I'm confused.
Anyone know the truth on the 2009's? Do they have enough cooling to handle towing?
It is looking like a Honda Ody for me.
Mike
I have the 2007 Sienna brochure, and here's what it says:
Tow Prep Package - 3500 lb towing capacity with heavy-duty radiator, heavy-duty fan, 150-amp alternator and power steering oil cooler.
I got it on my 2007, because I think those things are useful in other ways.
According to the dealers, the 2009 Sienna's are not coming with the tow package option and therefore a hitch can not be added. This tow prep package was standard through 2008.
Here is the response from the Fred Anderson Toyota
"Unless it comes from factory with the tow prep package, it can't be added here unfortunately. So if you need one with the tranmission cooler and the ability to tow upto 3500lbs, then it might be out unfortunately. I still don't know why toyota removed it from the standard equipment back from 2006. My guess is that they put the 3.5L motor, stability control, etc in them and didn't raise the price, so something had to go."
Mike
On my 2007 it was standard on the model I got, LE with package 3. Not an option listed seperately, but part of that model.
I'm adding the hitch myself for hauling bikes and will ad a cooler if I decide to tow.
Did you find solution ??????
I am in the same situation i just bought 2010 sienna LE and i need to add towing Hitch.
Not for towing purpose, i need it to protect my car from stupid drivers when they try to park/leave behind my car.
I had to repaint my BMW 325i bumper 2 times.
the good thing that my insurance cover that.
the bad thing, it will be registered in car carfax history.
Thank you for reading and advices
Tommy
Just a thought but be very careful not to damage the exhaust.
How much ground clearance did you lose at the rear? Departure angle I mean.
Found it for $150 on-line, did that price include the wiring harness? Was that plug-n-play or did you have to splice wires?
I have a 98 Sienna and would like to know if it will handle towing a two horse trailer. I don't have a specific one in mind because I don't know if it will work.
I also would like to know whether it will be a job my husband would be able to do himself. He's handy, but not a Toyota tech.
Thanks for any information.
It's a Toyota 2004 Sienna AWD with factory installed Towing package. Can I pull this boat/motor/trailer without long-term damage to the van (48,000 miles) described above? It pulls the boat okay but it sure seems to work hard up and down hills.
Will additional items (air bags, etc.) help? Can they be added at home or what?
You're not at the limit so you may do fine without them. Plus you know they exist if you do end up needing them.
Just do this - subtract 300 lbs from your max payload capacity. If you do not exceed that, it should do just fine.
People who tow very heavy loads get air bags to keep the rear suspension level, but I'm not sure you'd even need those.
wanted to hang a wheel chair lift on my 2010. The short answer to your question
is "Yes", in my opinion. It seem Toyota routinely equipped the vans with the
capability to haul anything up to 350 lb TONGUE weight until about 2008 or so,
at which time they degreed 120 lbs. was the max tongue weight without the towing package installed. Two Toyota dealers and a pro mechanic have advised me the only difference in the with/without is the radiator and oil cooling upgrade, and the suspension is the same either way. I'd think your two restrictions would be the 350 lb tongue weight and the hitch capability. I'd install a Class III
hitch as they cost about the same as a Class II. The Weight towing rating for
the Class III is a total of 3500 lbs.. Class III has a 2" receiver and the II
is 1.75", I believe. U-Haul installed my III for about $200, without the
lighting connections. You can buy a custom connection kit (plug in connectors
wit no cutting and splicing) online for about $35-40 from E Trailer and do the
lights yourself. I think they even have a video you can watch of a guy doing
the installation. U Haul wanted about $70 more to installation for the lights.
An ultra light trailer should give you no problem.
The reason for the change in 2008 is that the Tow Prep Package was standard on the 2007s. That was a little cost cutting they did.
Mine came ready to go, 350 lbs tongue weight straight from the factory.
300 miles,
Van pulled the trailer fine, I believe the 2002 models came with the tow package even if they did not come with a factory hitch.
the new model 08 etc: std models do not come with the tow package, it must be ordered when vehicle is ordered new.
you should have no problem but do get the trans oil flushed, I did it at 60k then again at 110k just look at oil and if it starts looking dirty get it flushed.
i already have a reciever installed and wires...but...do not have the tow package IE:larger radiator, fans and HD alternator.
these are all to tow 3500 lbs...i am only going to tow about 1200-1500 lbs loaded...the popup is about 900lbs
do i need to install all this?
has anybody towed with a sienna that was not tow equiped?
I think you'll be fine. The normal payload of a Sienna is 1200 lbs, so that's just a normal full load, basically.
The tow prep package was standard on my 2007 (happily).
We are leaning toward XLE 8 passenger to get a power passenger seat for grandma, and occasionally haul the grandkids.
Salesman says the LE model requires a "Towing Prep" option, but that the XLE has it standard. Can anyone confirm this?
The Toyota website does not list the Towing Prep as standard on the XLE. It kind-of implys it by listing the Towing Prep as an option on the LE but not on the XLE.
etrailer shows a wiring harness that requires removing panels, running a wire all the way to the front for a battery connection, and then hanging the plug out under the rear hatch door. Is all that necessary if you have the Factory "Towing Prep".
My dealer does not have the Toyota receiver hitch in stock, and cannot supply good pictures of it installed. Anyone know how it looks hanging below the bumper cover?
And lastly, why have a tow prep option that does not include the receiver hitch?
Don
That would sure simplify things!!!
