Hyundai Sonata Pulling to the Right
I have owned my 2007 Sonata for 2 months. Last month while only going about 25 mph the gas pedal started pulsating and the ESC Off light came on. A couple weeks later it did it again and the steering wheel began pulling to the right and the ESC Off Light came on. Each time the roads were dry. I took my car into the dealership and they replaced the "YAW Sensor".
Yesterday while driving on the highway I noticed my gas pedal had a little pull feeling. While driving around 65 to 70 mph, my car was suddenly pulled to the right 3 times and the gas pedal pulsated. Dashboard lights flashed but none stayed on. I am so thankful that no one was in the lane next to me or I would have hit them since the car was pulled into the next lane. I went back to the dealership today and was told they could not "duplicate the complaint nor did the computer scan show any failure codes" and was basically dismissed. I wasn't accepting that and the service manager has now contacted Hyundai which says they have not heard of this problem at all and he also called his regional rep to see how he'd like to handle it.
Has anyone experienced what I describe above with their Sonata? I do not feel safe driving this car.
I have decided not to drive on any highways to avoid high speeds and in so doing have had to add 20 minutes onto my commute to work.
I called the service manager today and he said that his district rep wants me to bring the car in so that they can take all the tires off and "manually" (what did people do before they had computers?) inspect every part and all the sensors. I pray they find out what is wrong so that I can truly "drive" my "new" car. They can't get me in until Friday...
Thank you very much for your response and depending on the outcome after the inspection on Friday, I may have to insist on a loaner.
Did they fix yours?
"Cause: Found loose pin 37 on connector no EM02. Pink/Black into Pink wire YAW Sensor to ESC Module. Part # 914000A030
Bob Stepanovich Tech Training Instructor assisted. Dealer contacted Hyundai Technical Training Instructor for assistance in diagnosis repair wiring Connector Push Pin was not engaged into the lock all the way."
Since I had this repair on 8/30/07 I have not had any more problems with the ESC & ABS.
Please let me know how it turns out for you.
In short the connections into one of the sensors was pinched and causeing the ESC to engage the ABS system.
At any rate it took them 5 times to get it right. So far so good. Now I can enjoy my car and drive it with my family safely.
Once again thank you for your response to my post.
