Ford Escape Tires and Wheels
Has anyone else noticed rust appearing on the brake drums of the new 2008 Escape. My car is only 3 months old and I noticed rust around the inside of the wheel covers on all 4 tires.
This is just surface rust and won't harm anything. The rotors are constantly scrubbed clean by the brake pads.. The 2001 had rear discs probably so you didn't get rest.
Mark.
The reasone for my quastion is because that I do own 255/70 16 winter tires from my last car, but I dont now if I can put them under my new Escape or not.
Does everyone have this problem - and has has anyone found a solution for this: My front tires throw so much road slush/salt and water on the sides (and around the front fender) of the vehicle that it even gets up on the side windows. After a trip yesterday I had THICK ice/slush/salt build up on the sides. This can't be good for the paint, especially if it throws some pebbles and debri against it.
Has anyone found a fix or product for this problem - some kind of guard or extension that can be placed around the tire opening on the fender that catches this stuff, maybe a piece of plastic that fits around it and sticks out 3" or so? Mud guards do nothing (except look cool...)
I noticed even at the car wash when I drive away slowly, any water I cross gets flung up on the side doors.
I did look on the internet but maybe I'm not searching the right
The pricey fix - real custom painted flares from: https://www.wooddashexperts.com/catalog/FORD_ESCAPE_Fender_Flares__ATS-p-38673.h- tml
And the more affordable extenders: http://www.jcwhitney.com/EASY-TO-TRIM-RUBBER-FENDER-EXTENSIONS-FLARES/GP_2008750- _N_111+2006+200005284+600013055_10614.jcw
I think we may try the affordable EASY-TO-TRIM RUBBER FENDER EXTENSIONS/FLARE and see if they help. Anything should help!
