08 Lancer Modifications
Hey guys, I already put in the aftermarket air intake on my 08 Lancer. It made a really big difference, but, I still want to make it louder and faster. The air intake GREATLY improved the mid range speed, but only slighty quickened the off the line speed. Any suggestions on what I can do? I have the ES, 2.0L, 4 cyl. I don't know how much more the engine can handle. It's REALLY hard finding parts and stuff for this car because it's so new! Any suggestions would be greatly appreciated.
To help with initial acceleration, you should try getting the light weight aluminum pulleys.
The best current place for a couple of performace mods for the 08' Lancer is RoadRaceMotorsports.com
Also, there is a forum/group of use who discuss how, where, and when mods are coming out at LancerTuncers.com
Hope this helps.
Bill
-mike
-mike
-mike
This is a custom ROAD/RACE CNC machined crank pulley. It is made of aircraft grade aluminum and weighs just 1 lb. Stock pulley weighs more than 4 lbs. and robs h.p. from the engine just to spin it. Just like a light flywheel, throttle response will be greatly improved!Installs in minutes and uses original belts.
-mike
-mike
-mike
-mike
