Hyundai Santa Fe Cruise Control Questions
in Hyundai
I have a 2007 Santa Fe Limited. As anyone who has this model knows, the cruise control is always "off" when you start the vehicle. The engage the cruise control, you need to first hit the "on/off" button on the steering wheel, and then hit the "set" button. Frankly, that two step process annoys me.
Every other car I have ever owned allowed you to leave the cruise control "on", so all you needed to do to engage it is hit the "set" button. My wife's 2007 Saturn Outlook is like that. It has an on/off button, but the button locks in the "on" position so you don't have to turn it on again every time you start the vehicle.
Does anyone know if it possible to reprogram the Santa Fe's cruise control so that it already on when the vehicle is started?
Caution: If you leave your cruise control on when you are not using cruise, you might hit a button and go into cruise when you do not want to. You could be startled and even lose control. Keep the cruise control switch off until you want to use cruise control.
SAFE Driving with Cruise Control!
I also think it is a good safety idea NOT to have an always on switch available so you do not accidentally engage cruise (heck, we are lazy enough!). (actually happened to me in a Honda that had an always on switch + start cruise switch.
Scared the %$^ out of me when I tapped cruise in error (at night) and I never left that switch on again (twas an 05 Element...you know the toaster on wheels! :shades:
2024 Ram 1500 Longhorn, 2019 Jeep Wrangler Rubicon, 2019 Ford Mustang GT Premium, 2016 Kia Optima SX, 2000 Pontiac Trans Am WS6
If you have the 2007 model and you have bought it bas a used car, then you'll have to refer to the dealership and get them to look up the VIN number which should show the original equipment that was on the vehicle.
Likewise, if it hasn't been done yet,there is also a way to program the door locks to close automatically when the vehicle reaches 15 mph. They do not, however, open automatically when you remove the key for safety reasons, only when you manually open the door from the inside.
Other info:
if you have the 18" tires then keep them at 30 psi (cold).
The little prongs on the inside of the circular gas filler door are for putting the gas cap in to hold it up when filling with gasoline.
The front headrests are adjustable; hold the button in and lift to raise or lower them, then push them all the way backward to release them to the most forward postion, then push them back click by click (4 positions)
Hope you have fun with your S. Fe., Ciao.
I have 2004 3.5 DOHC Santa Fe. Cruise Control was working until 3 days back alright. All of sudden now, it stopped. Cruise control light comes up if I press the on/off button. I tried to set the cruise after cruising at around 70 miles/hr but it won't engage and as soon as relieve the SET button the vehicle cruises down. I want to know what could be the problem and how much it could cost me to fix it? Rest everything is working alright.
Thanks in advance,
- Barkya
After I replaced both the bulbs, cruise control works fine.
I'm wondering what caused both brake lamps to blow.
AND I wondering why there was NO indication on the dash that two of the three brake lamps were out??? I went for 3 weeks before discovering the brake light problem. (The brake lamp in the middle top of tail gate was still working). This is a Definite safety issue that Hyundai should fix!
Did you ever figure out why both bulbs were blown?
Thanks to your reply/note I was able to get the cruise & the brake lights going again with very little fuss & cost..., Once I became aware that the brake lights were out. Thanks!
Two phillips screws removes the switch unit and unplug is easy from harness. There are two printed circuit boards that are perpendicular to each other and are electrically joined by four (4) soldered pins from one board to the other....a gentile wiggle of that joint revealed that the solder joints were broken on one or two of the four...... with a FINE solder tip you can re-solder those loose joints being very careful NOT to bridge one pin to another......repair 100%
When i set the cruise control on a speed say at 60k, the speed varies by about plus and/or minus 5k. In other words on a flat or slight (i do mean slight) the speed will rev itself to 65k or slows down to 55k. and if going downhill, the speed does not break at all.. just rolls to 70 plus. According to Hyundai Dealer in my area, he claims that is standard/normal for Hyundai which I find astonishing.
Anyone with same experience and any suggested solutions please? Thank you
