Ford Ranger gas mileage
![[Deleted User]](https://secure.gravatar.com/avatar/4cfa9da57b9053a706943b1982d84a02/?default=https%3A%2F%2Fvanillicon.com%2F81ac5cee35a34076f08d795cb3678052_200.png&rating=g&size=200)
in Ford
Can anyone explain to me whythe official EPA mpg on the Ford Ranger 3.0 and 4.0 liter engines has varied so much in the past seven years? I am interested in purchasing a used Ranger in this range of years. I would prefer a 4WD 4.0 liter with manual transmission. Since 2001, this engine has been OHC and 207 hp.
When I look at the pre-2008 EPA window sticker figures, the 2001 is listed at 16/20 (city/hwy); 2002, 2005 and 2006 are 16/19; 2003 and 2004 are 15/19; and the 2007 is 17/20! Even more strange, the 2005 automatic is listed at 16/20, higher than the automatic for all other years and higher as well than all manual transmission year figures, save for 2007.
What gives?? Are there any true differences in the real world? Or were there pne-year-only gearing changes that caused the same engine to be more efficient? Over time, the differences between 15/19 and 17/20 could add up, so I'd like to know more about this before I buy. Thanks!!!
And, a Ranger is a truck. A brick on wheels.
For my 1994 4L automatic 2WD extended cab, I got about 14mph in town and the best ever gotten on highway was 18.5mpg. And this was the 165hp 4L, you are now looking at 207hp motor.
The 4 cylinder 5 speed manual will get somewhat better milage. But, in my opinion, that motor is a slow brick.
Don't buy a truck for milage. 4WD will just make it worse.
I loved my Ranger. But my Honda Ridgeline with 4 doors, 247hp, and full time 4 wheel drive gets better milage than the Ranger, especially on the highway.
BTW, I have owned three Rangers, 1986, 1993 and 1998 4WD models with 2.9, 3.0, and 4.0 engines respectively. They all got better mileage than what you report with yours. Yes, trucks are rather brick-like, and the 20 mpg or so I got with the 98 4.0 would have likely been even better on the highway, had it been a sedan.
But again, all I am looking for is an answer to why the 2001 to 2007 4.0 EPA mpg figures varied at all, given the truck was not redesigned, the engine was not changed, and it was prior to the EPA estimate changes of 2008.
Maybe someone else can help.
Ford Ranger , 2.3L ,mpg: 21/26
Che. Colorado, 2.9L , mpg: 20/26
GM Canyon : 2.9L , mpg: No list
Nissan Frontier: 2.5L , mpg: 22/25
Toyota Tacoma , 2.7L , mpg: 20/25
You can see that Ranger has the smallest engine but the mileage very much the same as bigger engine.
Why the pich-up truck (in general) has very low mileage ????? I can see the same (or smaller) engine size in the sedan and their mileage is around 30-35 range. It about 33% (or one third) more.
Since trucks supposedly are used to carry loads and tow things, many have a drive line geared toward this. Which reduces milage.
Because of the same thing, loads and pulling, sometimes the same motor in a car and a truck will have different cams and also 'logic' in the computer. They are set up to generate more power at lower speed, which reduces mileage.
JIM
and ive been doing a bit of early car research, and weve agreed on a small, regular cab truck, and i saw the ranger, i really like this truck, but theres so many other trucks
so i need to know the straight out facts because i'm just starting to get busy
school is starting, im having to read
Results, on my last trip ( Maine to Maryland and back) I drove 1157.1 miles on 37.796 Gals of gas-slips. Math says that's 30.6 MPG, average and includes driving around town while I was there and almost two hours of stop and go traffic jams through NY and CT on the way home. On the first tank - strictly highway and no traffic delays I got 32.4 MPG!
My old 4 cyl '93 Ranger had 5 spd. with 3.08 gears and never got as good mileage. The engine had to "lug" too much causing the intake vacuum to drop which means poor mileage.
I have no reason to "BS" you! Hope these facts help.
:shades:
All 4liters are the same. (Until they went to the overhead cam in what, 2000???)
On my 1994 4Liter, extended cab, automatic, with a cap on it all the time, it got about 14mpg in town, the VERY best I ever saw was 18.5mpg on the highway.
I had a 1992 4L, extended, 5 speed stick, and I got 18 city / 23 highway.
At what speed? My highway driving in the south/mid west meant 75 mph with the AC on.
It was at 68 - 73 MPH as I recall, that was a long time ago! My highway trips were between LA and Albuquerque, so my A/C was running as well. The speed depended upon the state - Arizona has the highest speed limits, but I believe that CA and NM had 65 MPH at the time, so I drove 68 in those states.
I had the limited slip rear end as well, which I believe actually reduces MPG.
Keep in mind that I had the 5 speed, and the fifth speed is basically an overdrive. NOT an automatic...
I get about 21.5 mpg combo of town & highway
Not bad for an old lady.
