Nissan Pathfinder No Start Problems
My 93 XE Nissan Pathfinder has had a problem starting for the last year and a half, it started out that i thought i had a bad starter. I went out and bought a starter, just to find out that it still had the same problem starting. I put in a cheater switch, too bypass the one in the dash. So that way the starter would turn, no matter what the key switch did. Well, over the course of the last few months it has begun to get worse again. To the point that not even the cheater switch is working anymore, just back to the fast clicking on the firewall or inner fender??? it has a brand new battery as well???
Does anyone have a clue, about what the heck the problem might be???
SUVs and Smart Shopper
I've got an 89 pathfinder and if all of a sudden wont start. It turns over and sounds strong turning over, and it smells like gas after I stop trying. I haven't had any problems with it. I just all of a sudden wouldn't start. I removed the air filter cover and then tried to start it and when I stopped turning it over it ignited out of the air filter housing. Just wondering if anyone had any ideas what it is?
Would appreciate some recommendations. Thanks,
Anyone can give me some clue?
to do this you will need a repair manual . some black wires are just grounds,
but some grounds need to be in there proper circuits or the e.c.m. wont know
what its reading. :confuse:
Try turning your ignition to ON for about 3 seconds before cranking and see if that helps any (idiot lights on, etc.). You may be able to hear the fuel pump "priming" the fuel injectors and that may help it crank easier.
Doesn't explain why it cranks fine in the afternoon, if it's been sitting all day.
After I left the car, he called me saying that the computer says that there is a defective key. He asked me to bring all the keys that I had to reprogram them. I did buy a key and remote from a locksmith a while ago and they programed it and it worked fine. I have only used that key probably once or twice. He told me that that key could alter the performance of the car. OK I brought it in. Today I get another call saying that the Nissan Service computer now states that the battery is bad. How can my battery be bad when it has so much juice that the car starts right up. Anyway now I am going to pick up my car and get a diagnose on the battery somewhere else. If it appears to be bad I will replace it and take it back to the dealer to continue the diagnosis. I do not know, but it seems to me that they are giving me the run around not to change the fuel pump.
Any opinions about this would be appreciated.
Oh, one last thing. I bought a K & N filter and right after I installed it, the reader on the dashboard that gives you the miles per gallon now reads an average of 14.9 mpg. Before I installed the filter, I was getting 17.2 mpg as an average. Any suggestions on this?
I will let you know if this fixes my problem. You might want to call NMAC and find out if there is a recall on your vehicle.
I just removed some extra cables as it is an ex police car, I think I may have cut out a ground cable?? any ideas
Did you get the problem fixed? The same thing just happened to me this weekend with my 2005 Pathfinder (~30,400 miles). First, it had trouble cranking, then the VDC light was on once it cranked. It eventually went away about ten minutes later. Then, it wouldn't start at all when I tried to re-start it two hours later. I turned off the A/C and everything else that could put extra stress on the electrical system and waited about 30 minutes. It cranked first try after that, but the 4WD was out and the differential lock display (the one situated in the RPM gauge that shows which wheels are engaged in the drivetrain) was out. I drove 30 miles home, then re-started it once I was there. Everything operated normally. I took it to the dealer yesterday, who found nothing wrong with it, except that the computer didn't recognize the key. So, they wanted to re-code the key. I'm suspecting that it's not the key, and after reading your post, as well as a few others, my feelings are stronger. Anyone else with some advice is welcome to respond!
may be the elctrical engineers working there are US citizens?
However now several months later am now getting the problem where it has failed to start twice, but if you leave it 30 minutes it starts ok. Does this sound like the valve in the fuel pump that is mentioned earlier in this thread ? - mine is now way past warranty period unfortunately.
Interestingly we also had the fuel gauge issue and had that replaced (not under warranty), and also the leaking radiator into the transmission ($6000 - fortunately Nissan USA paid this as a goodwill payment when i complained and opened a case).
Would not buy a Nissan again !!
:sick:
the dealer called me today to tell me that I need new battery ($133.00) and the (+) terminal cable is corroded and needs replacement ($310.00). This is on top of $94.00 diag. Fee. What a scam! But regardless, he says that s the reason for all the weird computer games!
I will p/u the pathy today and test it out. I declined the wire replacement and opted for a $31.00 patch cable. :sick: :sick:
I took mine to the dealer for gauge issues, and he had to drop the fuel tank to get to the fuel level sensor to replace it. The service engine light might be related to something else. If you are not up for an inspection, dont bother with the engine light for now. I will get you the total cost on my fuel level sensor tomorrow. IMHO, if you can reset your odometer reading every time you fill up; I would save the $700 for now, int this economy, I would put off all unnecessary expenses,
Let me know how it went.
http://www.carspace.com/badams1997/Albums/badams1997%27s%20Album/starter_sensor_- 0008%20(Small).JPG/page/photo.html#pic
">link title
