Hyundai Vercruz Start Stall Idle Problems
love my new Veracruz but have two annoying issues that I would like some feedback on
Ignition : It takes too many turns of the engine to start the veracruz. Around 80% of the time it will not start unless I try to do it a second time. My dealer has checked it out but cannot find any fault with the starter. I think it might have something to do with the fuel line but they also discounted that.
Radio: It I change the radion settings ( bass / treble etc) and then turn off the cra upon restart it loses these settings and reverts back to the old ones. This also occurs with radio stations and cd tracks.
Please help!!!
Please help!!!
SUVs and Smart Shopper
Any thoughts and/or suggestions out there ?
craigmri, "Hyundai Veracruz Initial Quality" #89, 13 Nov 2007 8:09 pm
After a couple hours they told me that that did not fix the problem and that they would change the fuel pump. Since it would take a day or so to get a pump, they provided a rental. Free. It fixed the problem and I just hope that the new pump is not the same as the original and goes bad again later. All in all, aside from a little inconvenience, I had a good experience at the dealer.
After reading here and around the web I found - at - http://www.aboutautomobile.com/TSB/2008/Hyundai/Veracruz/Fuel+System
TSB-09-FL-003-1
Summary:
or cold engine rpm fluctuation- tps replacement & ecm update. Some vehicles may experience either slight engine rpm fluctuation at cold warm up or malfunction indicator lamp illuminated with the etc
We took it the dealer and they perfomed that fix of the Throttle position sensor today and ECM update......so far so good it seems to be running much better...hope this fixes it for good.
