Chevrolet Suburban Power Steering
                    I need some help, I have a 2001 Chevy Suburban with 47000 miles on it. I went to drive it yesterday and it is hard to turn. There is a little fluid leaking from the under part. I am thinking it is the power steering due to it being hard to turn. Does anyone know if this is true and if it is, could this just be due to low fluid? And if not, does anyone know the price range for fixing the power steering in it?
____________________________________________________________
Let's do the math. You have power steering fluid leaking from the unit under your vehicle. Your steering is now hard to turn. Answer: Obviously if the fluid is low on fluid the unit will not perform properly. How much to fix? Best to get an estimate from a good indie repair shop. That will be cheaper than going with a dealer. The PS unit normally is an easy fix or replacement.
JMDB
Is there a P.S.filter where I can't see? Or do I just need to bite the bullet & throw another pump at it?
You say turning left is light as it is supposed to be but turning right is a work out.
Obviously pump is working as left turn is ok so you need to look at the power steering unit, i.e. possibly replace it. Should not be too expensive job either.
Arrie
SUVs and Smart Shopper
All of which I have brought to my dealer for diagnostics:
1) The loose linkage was "repacked" with grease about 4 years ago under warranty and came back about a year later after the warranty ran out of course.
2) The right turning issue was diagnosed as a bad steering gear which would entail replacing the steering box at a price of well over $1K
3) The free feeling wheel I was told is related to the steering gear box. Dealer told me none of the items are safety issues but would cost $$$$'s to repair.
So, at 158K miles, I have made the executive decision not to do any steering repairs until either something starts leaking on my squeaky clean garage floor or I hit a tree. We'll see how that goes...so far so good!!!
We still love our Suburban by the way...it's by far the best out of the 5 we've had to date.
Thanks for any help!
Drove vehicle on highway today. Wheel turns right okay, left with very little hangup at highway speeds. when stopped at idle, wheel very hard if at all turning left and turns fine to the right. If u give it throttle while sitting still and turning left the wheel snaps loose and u can turn the wheel. the steering column area inside the vehicle makes a moderate to loud noise while trying to turn left sitting still (like air pressure escaping.) Hope this helps! Thanks for the Help.
something in the car repair world that I haven't fooled with much. This is my 3rd online repair site and no answer from anyone. I guess this world will never change! There is nothing free anymore, not even info. Maybe my wife will hit a tree and I will kill 2 birds with one stone. Don't have to fix power steering and she'll be gone. Damn thats wrong! Have fun all u backyard mechanics..
Should i go buy more power steering fluid? or would that be a waste of time?
If you are a hands-on self mechanic like I understand from your post try to disassemble the steering gear if you have time for that. Why I suggest this is that at least in my Tahoe there is some kind of a limit switch built in the gear. When I turn the wheels all the way right or left I hear some sort of a click or pop sound and power steering assistance stops. This obviously is to stop power steering from forcing the steering linkage against the end of travel limits.
If this limit switch gets stuck it means that power steering assistance does not work in direction the switch is at.
Unfortunately I cannot tell you anything more about this as I have not had any problems with mine.
Arrie
While I would think that I may have mis-aligned something during the replacement its kinda hard to do. The pitman can only be wrong 90 degrees at a time-so thats straightforward. The connection for the column to gear input shaft seems to be the more likely culprit but it only seems to go back on when the flat (keyed? bevel?) area on the spline matches the column joint. AM I RIGHT ON THIS? Can the column and gear input be a spline or two off? With the 11-12oclock steering wheel it could not be more than a spline. Again, it just didnt seem to want to mate back up any other way.
Yes, I marked them when removed but used new parts so had to transfer the marks from the old parts the best I could.
If the mentioned spline CAN BE INDEXED, do I need to do it at the column or by turning the rest of the steering. I realize the precautionaries (air bag) of turning the disengaged column-but 1 degree? I strapped the wheel during replacement but really dont understand the risk or whether a 1 spline index change would matter.
CAN I INDEX AT THE COLUMN/GEAR INPUT OR WILL IT ONLY GO ONE WAY ON THE 1999?
