Honda Pilot noise from center console when braking
trickstarjimmy
Member Posts: 1
Hi! We have a 2005 Honda Pilot, and when braking, there is a variable high frequency pitched noise emitted from the center console/a/c vent areas. It only occurs when the a/c is turned on. The noise is intensified when turning on the rear manual a/c control. When turning off the air conditioner, the sound does not occur. This seems like it might be related to the resistor failure or the rear a/c transistor block failure described elsewhere. Are there any more specific TSB files that address this? Thankfully, we're still under warranty, but, magically, it seems that we can't replicate the noise when going to the dealership. I'm just looking for information to pass along to the service personnel. Thanks for any help! Jimmy
I've been back to them twice over the last 4-5 months to redo the brake work because the sound has not gone away. Today, they told me they needed to replace the rear A/C motor or resistor and it would be about $500.
I came home, got on Google, and found your post! It took me a few minutes to find it because I don't spend much time up under my car, but I cleaned out the rubber nipple (it had a bunch of 'glop' up in it) and a lot of water came pouring out.
I'd really like to clean the motor filter as you mentioned, but I don't know how to remove the plastic off the console. Could you provide any instructions as to how to do that so I could avoid breaking something? Also, once the plastic is off, is it fairly obvious where the filter is?
Thank you -- I haven't had a chance to drive my Pilot much yet, but here's hoping you saved me about $600!
- ClarkL
Had the same problem with my 2008 Pilot. Thanks to the post above by dustink in 2008 I was able to unclog the drain and stop the sloshing and squeaking.
thanks a lot i had the same problem on my pilot 06, now its gone. cheers
