Ford Explorer Cruise Control
I have a 1997 Explorer XLT. Th cruise control switches (on steering wheel) need replacement. I located replacements, but can't figure out how to install them. I think the air bag cover needs to come off but not sure how to do that either.
It works OK, but the surface is badly deteriorated and damaged. Does the horn/bag cover just pry off exposing the screws? I bought the vehicle used but in pretty good shape otherwise. (41k miles)
The manual I have (for my 95 Ford Explorer) says to disconnect the batt. and on the side of the steering wheel are two plugs that cover the two bolts that hold the airbag module in place.
I need to replace the RSM switch on my cruise control. I got a switch on Ebay but it has 6 pins and my switch has 7 Do you know how to determine the if the 6 pin switch will work?
