Isuzu Rodeo Battery Problems
octaviaoctavia Member Posts: 2
edited June 2019 in Isuzu
I have changed battery had it checked and change altn. and had it check. battery lose power and everything stop. I at a lost on what could be the problem. Help please
  • rodeojeffrodeojeff Member Posts: 4
    i am haveing the same problem with my 1995 rodeo, hope we both get a solution
  • al3ph1al3ph1 Member Posts: 3
    Either of you find a solution? Having same problem with 97 Rodeo. Started right after replacing a bad alternator. Had new alt. tested. It's good. Battery is good. Tested wiring and everything checks out. Only thing I can't test is the ECM. Don't have Check Engine Light on or any other lights other than the Battery/Charge light on.
  • mcdonmcdon Member Posts: 2
    I just went through this problem. I found out that the regulator was bad in the alternator. This was after I had taken the rodeo back to the auto parts store and had it checked. Then I was not satisfied so I took the alternator off and took it to have it check, An both times it show it was charging.The people at the auto store said I may have broke a wire when I took it out. By this time I had check all of the fuses,relays and rechecked the wires. I had called a auto electrical place and a Isuzu dealer and the auto elect. got his hot line and found out that a lot of peole had the same problem and 95% were the alternator.So today I took the alternator off again and took it back and I talked to a different sales person and was telling him what I had found out. An the first words out of him was that regulator was bad. I wish he had been there two weeks a go.So know the heating and air conditioner our working and the dash lights or off and the amp hand is working. I am sorry to tell you at first that this was 1996 redeo.
    I hope this helps. mcdon
    Thanks for the reply. Ended up going to a mechanic who said what I suspected - alternator is bad. I had done all the things you did. I checked fuses, relays, etc. prior to taking it to a mechanic Guys at the parts house reluctantly replaced the alternator yesterday (after I spoke to a manager). One guy was asking if they checked the fusible link (trick question). Told him they and I checked the fuses and relay for the ECM, etc. and that shut him up. Anyway, new alternator works fine which means the regulator was bad (just like you mentioned) in the old new alternator.
  • jasenjasen Member Posts: 2
    i was wondering how to check the regulator the part store said the altonater is fine
    Not sure. My alternator was still under warranty, so they replaced it. I have a book at home, I can check to see if it shows the steps to replace the regulator.
  • mwolfemwolfe Member Posts: 7
    I was driving along happy in my 97 Rodeo, when all of the sudden, my A/C and fan motor went dead, and my brake, battery, and 4WD indicator lights came on. I checked fuses, and immediately suspected an alternator issue, and got a replacement from Advance. I replaced the unit, but no change. I checked fuses again, and switched relays around, nothing worked. When I took the core back, I had them test it, and they said it was only putting out 10 volts. I took the new one in and had it tested, and it was OK. I took it to the dealer, and they said that the aftermarket alternators aren't any good. I new OEM was around $500. I went to NAPA, and picked up another and put it in, again nothing. I noticed that unplugging one of the harnesses to the alternator enabled my A/C to run. Further playing around, I found that there is a Red wire with a white stripe that leaves one of the two alternator harness connectors by the engine fuse box. Once I disconnected that wire from the harness connector ( it comes apart ) my alternator is charging, and everything is back to normal. This wire connects the alternator to the computer, and I believe serves some enabling function. When I connect even my digital volt meter to the alternator on that pin, it cuts the alternator output. When they tested the alternator at the store, they basically hook up 3 wires: ground, 12 in, 12 out. The wiring harnesses provide like 5 paths plus the chasis ground. I will eventually get the OEM alternator replaced to verify, But in a pinch, I hope this helps. I just think there's an Isuzu specific circuit that isn't verified by the re-manufacturers, and that's why 95% of these don't work.
    On the plus side, I've had the alternator out so many times I can replace it in about 15 minutes while the engine is still hot :P
  • orlando11lugoorlando11lugo Member Posts: 1
    The problem is all the same as everybody else.Its not the regulator that is inside the alternator.The problem is the Harmonic Balancer went bad so its slipping so the belt turns slower than normal given you all this problem.Hope this helps .
  • seven10seven10 Member Posts: 1
    Thank you so much for taking the time to write that. I had the same thing happen to me 100% the same with the indicator lights and everything. I'm not sure the cause of this problem,but disconnecting the wire harness worked for me. Saved me a ton of time and money. Again thanks for your input.
  • klanenewklanenew Member Posts: 2
    edited November 2011
    My 2004 Rodeo sat for a few months before I bought it. The batter would not hold a charge. Once I was 'jumped' I could drive with no problem. I took my Rodeo for an oil change; then my 'check engine,' 'ABS' and 'check 4wd' came on. Any ideas what the problem might be? I also put in a new battery too. Thank you.
    My Check 4wd light is on and will not lock into 4wd. Any ideas, it is electrical too. Thanks.
  • repofirerepofire Member Posts: 1
    After reading previous post, I cut the red/white wire near the plug and ran wire from plug to battery positive post, pretty much bypassing alternator, and it still tells ECU whats going on with charging. All systems back to normal, from dash lights, and AC all working correctly. Thanks mwolfe for bringing this to our attention. This post really helped me with solving these issues.
  • unknown21unknown21 Member Posts: 1
    I have a 1998 Isuzu rodeo & everything was working fine until I tried turning it back on it wouldn't start anymore ..they battery is fine but it won't start for some reason ..can someone help me out here .
  • phxbird57phxbird57 Member Posts: 1
    I have a 1998 Rodeo. The problems was after driving for one hour ( highway driving). The battery & brake light would start flashing. Then if you continue diving the TAC & speedometer would stop working the battery & brake light would stay on and also abs light would come on. Continue driving and It would start losing power. If you pull over for a little time you could start driving and it would act normal. I had Napa , autozone and O'Riley check the battery & alternator both test and no codes. The lights started coming on sooner. It ended up be the alternator. I hope this may help someone.
  • olefisholefish Member Posts: 1
    I have an 1999 Amigo and it does not have a red/whit stripe wire. But it does have a plug at the bottom of the fuse box on the engine side with 2 wires going to it, that run down to the alternator. Is this the same location as your Rodeo? I did un plug it and the battery and brake indicator went off. Thank you for the info
  • TheCapnTheCapn Member Posts: 1
    Just an update to what mwolfe originally posted:
    On my 1999 Trooper the referenced red/white wire is a white/blue wire. Still connects to the PCM at C12. This is from the shop service manual. Thanks!
  • BACKYARD57BACKYARD57 Member Posts: 1
    I have a 1996 Isuzu Rodeo 4x4 v6. It's a college car for my daughter, and has had chronic belt squeals. Changed belts no change. Thinking the alternator was dragging (also charging needle would drop at times below 12V, and air conditioner would drop out) I changed the alternator-no change. Finally found that the harmonic balancer had gone bad and separated where the fan, and alternator were pretty much free-wheeling. So I put a new harmonic balancer on and tightened all the belts and all the squeals were gone but the alternator and air conditioner still had the problems described above. Reading the above posts about replacement alternators not working sometimes I figured since I replaced the alternator it must be one of the non-compatible ones. As one post above suggested, I disconnected the red/white wire from the connector near the engine fusebox and bottom line is all is well now. Thanks so much for the posts, hopes this may help someone down the line.
  • I have a 1996 Isuzu Rodeo 4x4 v6. It's a college car for my daughter, and has had chronic belt squeals. Changed belts no change. Thinking the alternator was dragging (also charging needle would drop at times below 12V, and air conditioner would drop out) I changed the alternator-no change. Finally found that the harmonic balancer had gone bad and separated where the fan, and alternator were pretty much free-wheeling. So I put a new harmonic balancer on and tightened all the belts and all the squeals were gone but the alternator and air conditioner still had the problems described above. Reading the above posts about replacement alternators not working sometimes I figured since I replaced the alternator it must be one of the non-compatible ones. As one post above suggested, I disconnected the red/white wire from the connector near the engine fusebox and bottom line is all is well now. Thanks so much for the posts, hopes this may help someone down the line.
    I love it when someone finds a solution already posted. It's why we keep valuable information around!! Glad you were able to solve your issue and welcome to the forums!
  • AarinsinghAarinsingh Member Posts: 1
    Has anybody taken any pictures of this repair? I’m having a hard time finding the red/whiw wire to isolate. The book says white/blue and I have read some models were white blue. Where does it go to in the engine compartment fuse box?
  • jstengjsteng Member Posts: 1
    I'm having a similar problem with lower than usual alternator output on a replacement alternator. Anyone have alternators burn out after cutting this wire from the PCM/ECM? I believe it is meant to regulate the output of the alternator so it's not at 100% output all the time
