Isuzu Rodeo Battery Problems
                    I have changed battery had it checked and change altn. and had it check. battery lose power and everything stop. I at a lost on what could be the problem. Help please
I hope this helps. mcdon
On the plus side, I've had the alternator out so many times I can replace it in about 15 minutes while the engine is still hot :P
On my 1999 Trooper the referenced red/white wire is a white/blue wire. Still connects to the PCM at C12. This is from the shop service manual. Thanks!
