Nissan Altima 2007+ Maintenance and Repair
in Nissan
I've decided to create a new discussion since I've heard of a few problems relating to the '07+ models, notably:
Power Driver Seat Squirm - We bought my wife's Altima in July, and since August, the driver seat "squirms" slightly when taking a corner. There's no rhyme or reason to it, it shifts whether it's a left or right turn. The dealer (of course) hasn't found anything wrong with it, but other owners in other forums have suffered the same issue.
One thing discovered is that the seat will not squirm if it's at it's lowest setting, but anything above that will cause the squirm. The simple thing would be to keep the seat as low as possible, but my wife isn't comfortable in that position.
Can anyone else weigh in on this?
CRaymond
So far it hasn't happened under any other conditions (which doesn't mean it wont)
Anybody experience anything even similar or have any ideas?
ELECTRICAL SYSTEM:" SOFTWARE
Defect Description:
NISSAN IS RECALLING 204,361 MY 2007-2008 ALTIMA, ALTIMA HYBRID, 350Z, 350Z ROADSTER, MY 2008 ALTIMA COUPE, ROGUE, MY 2009 MURANO AND INFINITY MY 2007-2008 G35 SEDAN, MY 2008 G37 COUPE AND EX35 PASSENGER VEHICLES EQUIPPED WITH CONTINENTAL AUTOMOTIVE SYSTEMS OCCUPANT CLASSIFICATION SYSTEMS (OCS)
BEEN MANUFACTURED OUT OF SPECIFICATION. UNDER CERTAIN CONDITIONS, HIS COULD CAUSE AND INTERRUPTION OF SIGNAL BETWEEN THE OCS AND THE AIR BAG CONTROL UNIT (ACU)
Consequence Description:
THIS COULD RESULT IN THE PASSENGER AIR BAIG BEING SUPPRESSED WHICH COULD FAIL TO PROVIDE ADEQUATE PROTECTION IN THE EVENT OF A CRASH.
Correction Action:
DE4ALERS WILL TEST THE SIGNAL BETWEEN THE OCS AND ACU SYSTEMS USING A SPECIAL TOOL TO CHECK THAT IT IS FUNCTIONING AS DESIGNED. IF NECESSARY, THE SEAT CUSHION (CONTAINING OCS HARDWARE) WILL BE REPLACED WITH A NEW ONE MANUFACTURED TO SPECIFICATION. TE RECALL BEGAN ON NOVEMBER 4, 2008 OWNERS MAY CONTACT NISSAN AT 1-800-647-7261 OR INFINITY AT 1-800-662-6200
Hey its couple more recalls for this vehicle.
AIR BAGS #08V521000
ELECTRICAL SYSTEM #07V599000
ENGINE AND ENGINE COOLING #07v267000
and the smart key started.
The best thing also is to contact NISSAN.
Good Luck
