Nissan Pathfinder Transfer Case
I am new to this, and not quite sure how to go about asking for help...but if anybody knows the selection order of the transfer case gear selector of the 1990 Nissan Pathfinder SE 4W I would be so grateful if you could enlighten me!
1988 Nissan Pathfinder, V6, 4x4. The transfer case oil was changed 2 years ago.
A. Mileage – 149,000
B. Engine – V-6 SE
I have replaced the Air Conditioner system, radiator, EGR system, engine wiring, exhaust system, all brake housings,
The Problem:
No matter the temperature, the engine acts as if it is 30 degrees below 0!
The temperature maybe 90 degrees and the engine races at 2000 to 2400 RPM until the engine is warm!
This only happens on the first startup of the day.
What is causing this problem?
Best regards,
wheel12
2W - (all the up)
4H - (second spot)
N - (third spot)
4L - (fourth spot)
Does that seem right to anyone else?
B. Engine – V-6 SE
The Problem:
Best regards,
wheel12
