Please turn your caps off, it's hard for all to read.
You say this is your second Accord, and the first had electrical problems. Was the first one you had a dealer buy back, and what kind of electrical problems did you have?
From what I've read some of these are characteristics of all new cars. Like high idle at start. The Car does have more power and many more features compared to my 96, and it was only about 12% more than a new LX sold for 10 years ago.When I bought my slightly used 96, a new 97 LX was near $18,000. My much better equiped LX-P was $20,500.
I do have complaints, AC fan noise is most annoying. It seems to come on constantly around town. The car is a bit noisy, suspension too firm ,the handling is excellent though so there is a trade off, but I see why the old folks buy the Camry.
I still expect this car to outlast anything else out there, that was my number one reason for buying a Honda. I drive about 24,000 miles a year I need a car that can handle my long commute.
In 97, that was the best deal I could get at the time not the MSRP.
That's why I go by msrp for comparison purposes with the old cars.
1. The sound deadening material on the hood was loose in a couple of places. I just pushed in the plastic buttons.
2. I also found a nut on the engine intake. It was just laying there in a recess. I don't know where it came from.
3. I had to add 6 oz. of oil to bring up to full. It was full when I brought it home and there are no leaks. Hopefully it is break in usage.
I.e. speed bumps in a parking lot.
I noticed this in my '08 EXL-4cyl since the first week of ownership. Some people are reporting this problem in another forum. They had broken struts or strut towers.
bbrowncods -- I noticed your post about oil consumption in your new Accord. I have no idea if this CAN happen in a new car without being a big concern. But, I do know that in all the new cars I've owned, I have NEVER had this problem. I'm generally not too uptight about new car issues -- but oil consumption would be one thing I would be VERY concerned about. . . . in my limited experience, its not normal. If its leaking onto the ground, it might be something that could be easily tightened with no further problems. If its getting into the system and going out the tail pipe, I'd be upset and I'd do everything possible to make sure you don't have a new car that burns oil Just my $.02!
You didn't indicate when you determined that your oil was 6 ounces low. Could it be that you removed the dipstick too soon after shutting off your engine, thus not allowing all of the oil to drain down into your oilpan? Could it be that you may not have inserted the dipstick all of the way into the block, thus assuring that the indicated level might have been incorrect?
Good Luck
Mrbill
I had a damaged tire on my old 88 Accord. It vibrated and shook the steering wheel when braking. Rotating the bad tire to the back corrected the problem. The bad tire on the back caused no noticeable vibration, but I still replaced it because I was concerned that the tire may fail. The damage could be seen when I spun the tire on the back of the car.
Mrbill
I just noticed the phenomenon the other day while driving my wife's 2008 EX-L.
One problem that I had noticed with this car is that I get a rather annoying sporadic vibration when the car is idle (such as waiting at red light). The vibration + noise sound as if I had turn the A/C on for a few seconds, and turning the A/C off... and repeat. (The A/C is clearly off). I can feel the strong vibration not only from the steering wheel, but also from touching the dashboard too. The vibration and noise goes away as soon as the car moves away from idle.
I had noticed that one other person at ConsumerReports forum had reported this problem on his Canadian version of Accord EX-L I-4, but I just wanted to get a sampling of how many of you have experienced this problem and whether this "vibration at idle" is normal.
----I assume you are not referring to sitting at idle with the gear shifter engaged in one of the gears?? If so, that changes things . . . .
The car had been test driven one time before I bought it. However, since I bought it, I did a break in period on the brakes and I'm sure that I broke them in properly. Also, 4800 of the 5000 miles that are on my Accord are highway miles. So, the brakes have not been used in any stop-and-go traffic. . . Frankly, they have been used very little.
Any suggestions on what might cause either a glazed spot or a warped rotor with so few miles and under these circumstances. Does anyone know what does happen if a brake is abused when it is brand new (i.e. could of it been damaged during the one test drive--before I owned the car?)
I would appreciate any advise or opinions . . ..
Changes everything. Every 4 cylinder I've ever driven has vibrated at idle, particularly when in gear.
Car was taken in for service on December 31 for vibration and a thumping noise. It is still there. The service manager agrees that there is a problem and believes that the noise cancellation module that works in conjunction with the variable cylinder management (VCM) is defective. They are installing the new module today and then plan to test drive it to see if this solves the problem. Hoping to get the car back on Monday.
I've had it for about three years and I got the igniton coil replaced, a new timing belt, new spark plugs and fixed some oil leaks.
But once again I have another problem. Don't get me wrong. I love my honda. It's wonderful and I wanna make sure I can fix this problem.
Just recently I noticed that if my boyfriend drives my car over a pot hole or a big dip there is a bump noise and I can actually feel it under my foot in the passenger side of the car. It also makes the bump noise when I turn right a lot. I don't know what it is. Im scarred to drive it too far.
Also another minor problem is that when I'm driving normally not braking or anything the back wheels of the car will squeak a lot. I'm not braking. I don't know but if someone could give me advice that would be great! I need to know if my car is safe to drive or not!!! Please Thank You!
~Amanda
Since yours is a 1996 (fifth generation) model, and this forum is for 2008 (eighth generation) Accords, you might also want to participate in the Honda Accord (1994-1997) Maintenance and Repair forum here:
http://townhall-talk.edmunds.com/WebX/.efdf920?displayRecent
I would recommend telling your tire guy to take a hike.
78% Nitrogen, 21% Oxygen, 1% "Other Gasses"
Sorry, meteorology student here.
Hey, I am delighted I made it within 10% standard deviation! Thanks for the clarification. I stand by my opinion, it's a scam.
