Honda Accord (2008-2012) Maintenance and Repair
in Honda
Post all your maintenance or repair questions or experiences here!
Update: the problem has been diagnosed as a defective fuel pump. I have to wait a week for a new fuel pump.
Pre-Delivery Update: Low Power During Acceleration
link title
I hope this does not cause you problems down the road. Is Honda sure you have suffered no engine damage due to this, if possible?
I end up going every 7,000 or so with my mixed commute. It is at this point I hit 15% on the oil life monitor.
Let them take as long as they want to get your car back to you. . .there may be some benefit if there is real damage to the engine. Although I have never worked with California's lemon law (I think you said that is where you are from), it looks like you would qualify for relief only after your car is out of service for at least 30 days. Of course, the 30 day requirement is only one criteria among several. (see this web site: http://ag.ca.gov/consumers/general/lemon.php )
No matter where you are from, in most states, the longer your car is at the shop awaiting repair, the closer you get to qualifying for a buy-back. For your sake and so that you start enjoying your awesome car, I hope you never have to worry about the lemon law
Mrbill
I thought maybe it could be due to the cold weather here in upstate ny - bout 20 degrees-- and I checked to make sure no objects were in the car rolling around on that side...
Besides this- it is my second Accord and I love it!
I am going to have the dealer look at it during my first oil change.
Last Accord I owned '03 V6 was a rattle trap, hopefully, this one will be a little better.
My 08 was made in Ohio...I'll have to make a special trip to my dealer though as I only put on 5,000-7,000 miles per year now and do not want to wait till my first oil change (next October) to address this issue...
What are the outside temperatures? Winter blends and winter temperatures impact mpg too.
Since forever I guess. As noted, ethanol that is being used as an additive (up to 10%) in gasoline as a replacement for MTBE. Look on the pump you use - it'll tell you the mix. Most modern vehicles should not be damaged by the 10%.
E85 is a blend of 85% ethanol and 15% gasoline. Vehicles have to be designed to run on that blend.
robr2 is correct, while it has yet to catch on where I live in the south, in a large part of the country, 10% Ethanol is the norm.
Page 261 of the 2008 Accord Sedan Owner's Manual states: "Your vehicle is designed to operate on oxygenated gasoline containing up to 10% ethanol by volume and up to 15% MTBE by volume. Do not use gasoline containing methanol"
Only the driver's door unlocks for me. I'm frustrated, but trying to save a trip to the Honda shop. Has anyone else been successful doing so following the four-step instructions on page 84?
The 2004 wording is identical to the 2008 wording that I quoted in post #40.
I also will take it in to the dealer to get it looked at. I hope it can be located and corrected since the exact location is vague. Just for information this Accord was made in Alabama in 9/07. If any else has something like this please respond.
I really, really like this car and previously owned 2 Accords 12 yrs each and had an 04 Toyota Camry XLE for 4 yrs and traded it in for the 08 Accord. XLE was a little too mushy for me and wanted a tighter handling car. The engine power and drive is great in the Accord.
You know, I've actually relaxed considerably about squeaks over the years. I still expect a car to be tight and relatively squeak-free. But, I've noticed that Hondas and Toyotas are among the best of ANY vehicle. . . .and they still have some squeaks. I've had the chance to drive and ride in lots of expensive cars. Frankly, they have generally disappointed me when it comes to "squeakiness." I've been in many BMWs that are worse than the 3 Accords I've owned and I've noticed significant squeaks in Audis, Porches and Jaguars. I dont' have a lot of experience in Mercedes --perhaps they are quiet? Strangely, the quitest car I ever rode in was a 2001 Volvo Cross Country . . I'm not sure if the interior tolerances were so tight it didn't squeak, or perhaps they were so loose none of the pieces actually touched eachother
[p.s. - the loudest car I ever drove was an early-2000s model Mustang. It had been raced before --so maybe that was the problem. In that car, the tachometer was not necessary. . . the frequency of the buzzing plastic pieces clearly announced the engine RPM :P ]
