Dodge Ram Vibration/Pulsation/Bouncing
Hi all, I have a 2000 Dodge Ram 1500 QC Auto, 5.9,360 w/77k miles. When I'm driving between 40mph and 50mph and then apply the brakes it does a weird Vibration/seen in the side view mirror the truck bed bouncing and even in the cab also can feel it in the pedal. but really noticable on a down hill. I'm not sure if its coming from underneath the truck. vibration/bounce does peak at 40 and goes away at lower speeds and if its still there its not noticable. I did have a "tread" seperation blowout but tire was still inflated on my right rear, and it seems like every since its been doing this , Now I thought it was my brakes so I replace them not once but twice.. 1st time 07/17/06 new rotors and pads then on 04/30/07 to find myself feeling this pulsation/vibration or bouncing again so I replace again turned the rotors and replce the pads, NOw its 10/28/07 and still feel it so I replace the back brakes turned drums to notice they seem appear to be in very good wear after 4 yrs or so..but still feel this after replacing them. What other problem could this be causing this. is it steming from I was think maybe shocks, drive shaft, Would and alignment be in order??? Experiences? If i take it in I'm almost sure they'll just give me the typical "We didn't seem to find anything wrong". or " We looked underneath, and everything seems to look fine and have to give them 100.00 for looking.
See Also
Dodge Ram Pickup 1500 History
See Also
Drive line out of balance, (wheel bearing) Hub Assembly, calipers,
THEN BALANCED AND STAIGHTENED DRIVE SHAFT-REPLACED CENTER BEARING AND UJOINTS.
TWO NEW REAR AXLES-NEW HUBS AND BEARINGS.
NEW REAR ROTORS.
STILL THE SAME BOUNCE OR VIBRATION.
ANY IDEAS? THANKS, BIG AL
Dusty
Thanks for responding. The vehicle is driven daily.
Thank You,
John
I was thinking that the pulsation was from rust build-up from the pads being in contact with the rotor at rest for extended periods.
Dusty
Well, at least its something different.
Hope this resolves your problem and I'm glad your dealer is trying to support you.
Best regards,
Dusty
While i have put up with this problem to the point of just waiting to my lease to expire the truck is broken down again due to the tipm failure (which appears to be happening alot as well with the part being on back order and no eta of when it will get fixed) and without 4 wheel drive there is too much snow to drive around all i would end up doing is getting stuck.
Have you found a fix for your truck yet?
Steve
Ski in TX
2007 RAM 1500
between 50-mph up to about 60-mph, my truck has a very bad vibration problem, even tends to hum a bit under loads going up hills, seems like I'm losing power until I get back on level ground, then everything smoothes out. Does this with or without being in overdrive! The truck is in excellent shape. Maintained every 4000 miles. Does anyone out there have any clue's on what my problem might be??
Guy's at the local Dodge Dealership doesn't have a clue!! After spending close to $1,200.00 I still have the same problem as before. :confuse:
Ski in TX
Dont worry, be happy! Not much you can do about it.
Ski in TX
What specically is vibrating do you think? How fast are you going? RPM's at the time of vibration? Does it all the time or just sometimes? I have an 07 that vibrates sometimes but only between 50mph & 60mph in overdrive under a load (or slight uphill). Same deal or different?
Ski in TX
52103717A Isolator
5010321AF Gear Kit
5017438AA Bearing
68056356AA Seal
5072506AA BRG Kit
5072498AA BRG Kit
5013477AB Sealant
03400850 Diff Side Bearing
axle replace & side gears
0300102 Ring Gear & Pinion...original damaged upon inspection backlash noted
Prior to the repair today Chrysler replaced the drive shaft, rear shocks, torque converter, rear wheel bearings, rotated tires, replaced front tie rods...did software updates...none of these prior repairs had any effect.
Make sure you have your dealer or techinician check the rear end and factory specs at time of servcing.
**Make sure the techinician and yourself go for a test drive so the problem your experince is duplicated.
